Math puzzle.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rideandrepair, Nov 25, 2023.
  1. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    Ok, here goes. Cooling system has 10 gallons of 50/50 pre mix. Lost 2 gallons. Replaced it with 2 gallons of plain water. So if I drain 2 gallons and add 2 gallons of pure concentrate type antifreeze. What would the end result be? 50/50? More? Less? I’m at a loss. Should be close enough. Just can’t figure out what the exact ratio will be. Truck’s getting parked till spring. Don’t want to chance it. I have a cheap tester. Little floating different Colored balls. Do they work? I see better ones for less than $10. Something I’ll only use once. Trying to get rid of stuff, not buy any more crap.
    W923 and Flat Earth Trucker Thank this.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Well right now you have 40/60, what's the back of the jug say for temp it will freeze at for different concentrations?
    You could drain 2 gallons and add 2 more of the concentrated stuff the yes do add water stuff and you'd be at 52%coolant/48%water, close enough to call it 50.50.
    W923, Magoo1968, Diesel Dave and 2 others Thank this.
  4. rollin coal
    rollin coal Road Train Member
    13,605
    27,969
    Mar 29, 2008
    TN
    Eaay answer here, are you selling the truck? Don't worry about it man lol
  5. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,031
    Dec 31, 2010
    Washington, PA
    27. It’s definitely 27. I checked my work 3X.
  6. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    30%-13, 40%-23, 50%-35. I bought 2 gallons at Napa. On sale for $20 gallon. Cheap insurance. Be my luck to have record low temps.
    gokiddogo Thanks this.
  7. Big Road Skateboard
    7,085
    40,161
    May 2, 2021
    It'd be a safer bet @Rideandrepair to drain the coolant. You don't want coolant sitting on top of that piston all winter.
    I'd drain the coolant. Then turn it over by hand, or let it set for a day, to get the coolant past the rings. Then fire it up for a few seconds to blow the coolant off the top of the piston.
    At least that way it will set the winter dry. Otherwise, you'll have that coolant dripping into the cylinder all winter.
    Rideandrepair, Oxbow, W923 and 2 others Thank this.
  8. Flat Earth Trucker
    4,313
    16,552
    Nov 19, 2018
    You forgot to carry the remainder, add 4/5ths, multiply by zero, leaving the quotient indivisible, with liberty and justice for all.
  9. 201
    201 Road Train Member
    12,764
    26,262
    Apr 16, 2014
    high plains colorado
    Anti-freeze tester will tell you pretty quick. You know, way at the bottom of the toolbox from settling all summer,,what? No toolbox?
  10. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    You both forgot to find the square root of the common denominator then round it down to the nearest tenth and multiply it by pie +£ =¥
    Isafarmboy, Sons Hero, Oxbow and 4 others Thank this.
  11. Last Call
    7,568
    45,912
    Mar 15, 2021
    This guy ^^^^^ is right don’t ya know
    Oxbow and W923 Thank this.
