Maxi brake question.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by starmac, Aug 10, 2019.
  1. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Until maybe a year ago, I have never heard of long and short stroke maxis. I have replaced literally hundreds of them over the years and just bought 30/30 brake chambers or the 30/30 piggy back units and replaced them. Never has any of my suppliers ask if I wanted long or short stroke.
    What are each type typically used for.
    I am about to change all the maxis, and slack adjusters on my truck, and the maxis I have on hand are not marked either way. I have not checked to see what is on the truck, but they are not original anyway.
    stayinback Thanks this.
  3. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    You can tell the difference ,the short stroke cans have square port mount housings for your air lines,long stroke are round ports
    Rideandrepair and BoxCarKidd Thank this.
  4. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    OK, what difference is there as far as application?
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Think you might have gotten that backwards. Basically, the long stroke gives you additional stroke before your brake is OOS.
  6. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I have looked at the dots specs for oos, and never seen two different specs before?
  7. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    2" for standard stroke Type 30, 2.5" for long stroke.
    Rideandrepair Thanks this.
  8. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I know they are 2 in and 2.5 in, but what different applications are they used for, in other words why 2 different ones? Was one used on trailers, while the other mainly on trucks?
    Did some truck manufacturers just decide they need a longer stroke than others?
    Why, when you go to any parts house to buy one, do they not ask which one you want?
  9. dibstr
    dibstr Road Train Member
    1,308
    931
    Sep 10, 2010
    The long stroke has about 1/2 longer maximum stroke than the standard. It also provides more braking power than a standard does when the push rod is extended further. That’s why you don’t mix them on the same axle and shouldn't mix them on the same vehicle.
    CVSA inspectors use any two of the three following identifiers for the L/S to ID them.
    1. Service instructions embossed or stamped onto the chamber.
    2. Tags showing the rated stroke of the chamber. These tags are trapezoid-shaped (trapezoidal) with information embossed on the surface.
    3. Square shaped air ports or a square shaped embossment around the air port.
    Rideandrepair and spsauerland Thank this.
  10. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    In other words either can be used for any application as long as they are all the same. it seems odd that if the long strokes only benefit is more braking power, that they would even make the 2 in stroke one.
    Which one did most trucks come from the factory with?
    Oxbow Thanks this.
  11. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Long stroke seems to be what comes standard if not disc.
