Maxim weight registration
Discussion in 'Heavy Haul Trucking Forum' started by Phoenix Heavy Haul, Feb 23, 2022.
  1. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    Wussup guys, I’ve been dragging a sled cor about 5 years but really never got past Georgia,SC,NC and Virginia doing mostly local moves.
    Im buying my own outfit and am in the process of eating everything up. And I read somewhere that I need to register in each state for maximum weight or some states wont issue a permit for OW. Could some of y’all with more experience enlightenment me on this and where I need to do it?
    Since it’ll be all on me I may take some multi state moves and wanna be prepared.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Would be on your IRP. Pretty much standard for whoever does your licensing to just go 80,000lbs everywhere. That 80,000lbs max gross really only applies to the Interstate System. A lot of states have maximums higher than that. The states start issuing permits based on the truck already being licenced for max weight in that jurisdiction. If you want a permit for 120,000gross, you’re licenced for 80,000gross but that states maximum is 105,000 they won’t have a way to permit you for the portion between 80,000 and 105,000.
  4. Rontonio
    Rontonio Road Train Member
    6,483
    47,863
    Aug 9, 2009
    this is not correct.
    IA,MN SD,OK will require you to have the weight you wish to permit for on your IRP cab card.
    IA won’t issue otherwise but MN will issue but your permit won’t be valid.
    there are other states like WY,OR,WA, LA that you can register for more but if you aren’t they will still sell you a permit and charge you for reg.
    cke, D.Tibbitt, Landincoldfire and 5 others Thank this.
  5. nikmirbre
    nikmirbre Road Train Member
    5,584
    10,336
    Jul 27, 2011
    High Point NC
    @Rontonio had it correct. Its the registration weight on your cab card. Just register for the max weight allowed in those states..... I dont have a list of states cause I dont feel like pulling my cab card out LOL
    cke, D.Tibbitt and Phoenix Heavy Haul Thank this.
  6. Phoenix Heavy Haul
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    Thanks for the information.
    So the only states I need to worry about IRP max weight would be IA,MN,SD & OK all the others I can just file for a single trip permit?
    cke Thanks this.
  7. kranky1
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Things have changed a since I moved anything large down there. You don’t need 6 licence plates and two acres of fuel decals on the side of the truck anymore either. Our regs are still a little messed up but we only have 12 jurisdictions to sort out. And our weights are way different. Permitting isn’t as much of a headache for our low beds and double drops when the trucks are registered for 8 axles and 140,000lbs to start with for the trains. Generally we’re only permitting for dimension. If I have to permit weight for more than a couple thousand on an axle somewhere, then it’s an engineer approved permit and jeeps and boosters are out.
    cke Thanks this.
  8. TripleSix
    133,272
    Yep. Got a ticket for 18000lbs over because I crossed a scale with a permit, but not enough weight on my registration in Minnesota.
  9. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    A max weight tag only adds a few hundred to the cost.
  10. bumper Jack
    bumper Jack Heavy Load Member
    887
    4,412
    Dec 5, 2021
    No Connecticut and New York are the same way.
    cke, Phoenix Heavy Haul and beastr123 Thank this.
  11. beastr123
    beastr123 Road Train Member
    2,950
    24,198
    Jan 2, 2014
    Moose Jaw SK CAN
    It is well worth doing the research to register for the maximum you can in the area you work in, because the fines that can be incurred from one state can be multiples of the fees you pay.
    The delays to update your registrations and cabcards so that you can permit your load can also be darn expensive.
    D.Tibbitt, cke and Phoenix Heavy Haul Thank this.
