Maxxforce 13 Engine Fan Conversion
Discussion in 'International Forum' started by trulytex, Jun 21, 2018.
  1. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Wow i never knew. Good luck with that mess. I don't mean oil mess, i am thinking MAX FARCE.
    trulytex Thanks this.
  3. trulytex
    trulytex Light Load Member
    63
    24
    Feb 6, 2013
    Okeechobee, FL
    I have put nearly 70,000 miles each on my 4 day cabs since I bought them 6 months ago. They run 7 days a week delivering tankers of milk on local runs, sometimes 24 hours a day. So far I have been pleased with them overall, especially for the cheap price that I paid for them!
    Tug Toy Thanks this.
  4. trulytex
    63
    24
    Feb 6, 2013
    Okeechobee, FL
    Update: I changed the fan out and replaced it with the original set-up. We Replaced the front Engine Crankcase Oil Seal 3 times and couldn't get it to seal. Then found out that it takes a Special $525 Tool to install the Seal properly. The Tool Part # is ZTSE4873, I borrowed one from my Local Navistar Dealership and got the seal installed properly without problem. I found the tool on Ebay and offered $200 for it and they took the offer, so I now I have my own.
  5. Mad dog logistics llc
    Mad dog logistics llc Light Load Member
    152
    37
    Jan 13, 2014
    I have a prostar that the fan never turns off any suggestions its electric and Rush says there is no solenoid it has power to the plug (5 prong) and gives a code
    spn 647
    oc 126
    fmi3
    sa 0
    pin N/A
  6. Heavyd
    Heavyd Road Train Member
    7,831
    6,283
    Feb 4, 2009
    There are some voltage checks at the plug, if they are inspec, you replace the fan clutch.
    Intothesunset Thanks this.
  7. Mad dog logistics llc
    152
    37
    Jan 13, 2014
    Any idea were to find what voltage should be were? One had 24 other were 10-12
  8. Heavyd
    7,831
    6,283
    Feb 4, 2009
    This is for 2010+ Maxxforce series.
    Engine side of the harness
    Pin 2 is 5 volt reference
    Pin 3 is 12 volts
    Pin 4 is ground.
    Pin 1 and 5 are just signals.
    Fan hub side of the connector
    Check resistance between 1 and 3. Spec is 6-16 ohms. If open or shorted, replace fan clutch
    Check resistance between 2 and 5. Spec is 2500-4000 ohms, if not, replace fan clutch.
    QUALITYTRUCK Thanks this.
  9. Mad dog logistics llc
    152
    37
    Jan 13, 2014
    Checked the volts I do get 5 and 12 on engine side
    On fan plug
    Between 1-3 there is 8ohms
    Between 2-5 0ohms
    I ordered a new fan clutch from Fleet Pride 950 bucks. It looks like you just unscrew the big bolt counter clock wise am I correct or is there more to it that this?
  10. Heavyd
    7,831
    6,283
    Feb 4, 2009
