And body in the Kansas City area that can hook a scanner up to a 2012 international 4400 with maxxforce dt466 want to check oil and high pressure psi readings, to see if there an issue with the high pressure system or not.
Maxxforce dt466 no start cold
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by truckerbangin, Jan 8, 2021.
Are you using the proper winter grade oil?
Especially on an International engine. -
OK, I was assuming the truck was running and starting until the cold weather.
What winter oil are u referring too?
