Maxxforce power steering pump
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jhncp, Feb 4, 2020.
  1. Jhncp
    Jhncp Bobtail Member
    41
    Feb 4, 2020
    I have a 2010 Transtar maxxforce 13 and it is pushing black engine oil out of the power steering reservoir. The only logical explanation I would think is the ps pump. Am I right and how do I go about changing/fixing it? Thanks
  3. Jhncp
    41
    Feb 4, 2020
    About a year ago the fluid would get low occasionally I'm guessing ps fluid leaked into engine oil but now opposite
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The P/S pump has a seal in it that works both ways it needs to be replaced, or if you have plenty of $ you can buy a new pump?
    BoxCarKidd and Jhncp Thank this.
  5. Jhncp
    41
    Feb 4, 2020
  6. Jhncp
    41
    Feb 4, 2020
    I'm poor so if I can just replace seal that would be great. Any advise where pump is and how to go about it?
  7. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    OK sorry just find p/s steering lines and they will led you to pump, unbolt pump and seal will be in back of pump, buy seal 1st just to be sure you have it before you take it apart?
  8. blowing smoke
    blowing smoke Bobtail Member
    Where do you get the seal , not listed at my dealership
  9. Heavyd
    Heavyd Road Train Member
    7,810
    6,262
    Feb 4, 2009
    We don't replace the input seal on power steering pumps at the dealer level, we replace the pump. You would have to take the pump to a hydraulic specialty shop to locate the seal.
  10. blowing smoke
    Im glad to hear from you heavy D, I have 2009 Maxxforce13 , oil leaking out of road draft tube ,this version doesn't have oil separator with jet plate. a bad check valve or blocked return line from cyclone is my guess ,am I on the right track ?
  11. Heavyd
    7,810
    6,262
    Feb 4, 2009
    Probably just a plugged filter in the box with the cyclone.
    spsauerland and blowing smoke Thank this.
