MBN Turbo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by russtrucker, Dec 17, 2014.
  1. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    We took our t600 mbn to cat shop in milesburg to inspect/replace main bearings. I got phone call from this morning saying that the turbo has minor problems. We went there and showed us the damage on intake fin with dirt on it. I believe its the air filter I didn't replace yet. Dad wants just to replace cartridge. Whats your advice, just buy the whole new turbo or just cartridge?
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If housings are fine , nothing wrong with just a cartridge.
  4. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    So, it's just taking two housings off and there's the cartridge.
  5. wore out
    wore out Numbered Classic
    17,309
    214,783
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I do a lot of cartridge only. If your fins are pitted from dirt then I would say you have a leak on the inlet side. Usually a bad filter will plug up and starve it for air if it needs replaced. I would check all my tubes and seal on back of filter even if replacing it. If you don't find where it's sucking dirt your gonna overhaul it sooner than you want
    magoo68 Thanks this.
  6. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    I would examine the exhaust housing closely, the turbine housing and exhaust manifold are known to crack or even erode away.
  7. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    +1 ; Found the turbo divider plate cracked on my MBN, Cat wouldn't accept it as a core, wanted almost $3500 for turbo & core (this was about 5 years ago); $2200 walked out of parts house with brand new Borg Warner. Traded that truck 400k mi later, turbo was working great at that time.
  8. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Toss that $4500 cat turbo on the junk pile and put on a Borg Warner S410G-175963 for $1786 (that's what I paid anyway back in Jan.)
  9. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    I would hold off on a Turbo replacement; Pitted fins aside, i would be more concerned about leaking oil from seals: After checking the air inlet tube for leaks beginning at the air filters housing, chkg all clamps for tightness. Change your air & oil filters regularly. Just put the turbo on a watch list...it may still have several years of life. If, u replace ur filters.
  10. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    My uncle had that problem with his turbo. It only lasted him 4 years after noticing the damaged fins.
  11. SmokinCAT
    1,773
    1,488
    Oct 20, 2010
    To change to a standard replacement turbo on a mbn the ecm needs to be flashed to disable the ecm controlled wastegate, a BW 177148 would be more ideal, the 175963 has an exhaust housing that is too big to work on the 14.6L engine and would need to be swapped with a smaller one to work properly.
    russtrucker Thanks this.
