Mechanical N14 maximum OE hp
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Oct 31, 2025.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    I’ve found a good mechanical N14 core. It’s from a truck, so no JWAC. I say that, cause nearly all the mechanical N14’s in my area were in CIH Steiger and were all water to air. Anyway, Interstate McBee has a N14 CPL listing and some listings are STC, which is the mechanicals. Are any of these listings, mechanical N14’s I’m missing? I want to see what the cam and injector numbers correspond with?
  3. W923
    W923 Road Train Member
    1,419
    4,387
    Feb 28, 2022
    Not exactly following the question but all stc engines will be mechanical style and (in my limited experience) any high horse ones that aren’t stc will be stationary type engines that are basically intended to run a constant rpm
    As far as how much power one can make in a daily driven truck I probably wouldn’t want to cross 600 and only for certain drivers
    there used to be 2 fl classics around here with mechanical n14s that would smoke about anything else from the quarry….the owner is mostly retired and can be a bit of a donkey butt sometimes but on the off chance I run across him on the right day I will see what I can learn
    Not sure on your intentions but Cummins seems to be losing interest in those engines very quickly
    @OLDSKOOLERnWV can probably add some information to this thread
  4. OLDSKOOLERnWV
    19,114
    289,027
    Tag still on the block, if so what’s the CPL number….?
    Oxbow and mile marker 27 Thank this.
  5. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    The STC system was problematic. More so in higher horsepower engines. I would steer clear of them.
  6. IH9300SBA
    IH9300SBA Road Train Member
    2,428
    23,921
    Feb 26, 2021
    How so?
    ElmerFudpucker Thanks this.
  7. Inderjit
    768
    735
    Sep 17, 2017
    The ones I worked on would come in complaining about a miss under light load and heavy fuel smoke. The STC tappet in the injector had failed so pull the manifold and see which injector was making the smoke and replace it. The other complaint was running rough or missing under load. The barrel inside the injector would split or score causing the problem. It was harder to tell which one was the problem. A lot of times it meant replacing all six injectors. I could not tell you how many injectors I replaced, a lot.
  8. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    It’s not
    OLDSKOOLERnWV Thanks this.
  9. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    Naw, I’m not wanting to get crazy with it but was wondering if 500hp was doable with a mechanical(STC) cam and timing? I’m sure there’s other applications but a CaseIH 9390 4wd articulated tractor was around ~425hp, with that same engine. Of course it was water to air and timing would be different than a truck application. Higher hp from a genset or marine? I’ve practically had this engine given to me so I was just asking the brain trust before I get any more stupid ideas and follow through with them.
  10. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    I’ve heard that they weren’t as simple and on occasion, not as reliable as the PT pump but the tractors they put them in seem to held up great and were the best 4wd’s in there day.
  11. OLDSKOOLERnWV
    19,114
    289,027
    Get the serial number off the block below #6 head gasket on the left side. A call to the local Cummins dealer should give you the CPL number and HP it’s originally set at. You’ll have a good starting point then knowing what the internals are as far as pistons and camshaft….
    mile marker 27 Thanks this.
