I have replaced # 4,5,and 6 head and now have a water leak. It is not coming out of the head gaskets. There is water in the oil pan, oil pump and water pump. PLEASE HELP.
Mercedes 460
Discussion in 'Freightliner Forum' started by jrm6160, Feb 29, 2012.
first af all you did not inspected cyl. heads before you install. check the surface and resurface heads if you sugest they are bad.
may be you damaged one of gaskets. It is really easy.
Are you sure cyl. block surface is clean?
And overtorqued cyl head bolt may damage head ore block in thread area.jrm6160 Thanks this. -
How do you get oil pan from under truck without taking ubolts off?
with mercedes it is not so easy. especially on EU trucks.
well, there is wiring harness secured on front end of oil pan. unscrew this wiring box and keep it on engine.
Anyway I dit it in a hour. For me it is not a big problem to drop oil pan. But do not forget to separate oil level sensor connector))) LOL -
Thanks for your help. I hope we fixed the problem. I will know for sure Sunday.
Can you tell me the foot lb. on the front u bolts. I got everything back together and no LEAKS.
![[IMG]](proxy.php?image=http%3A%2F%2Fi48.photobucket.com%2Falbums%2Ff237%2FPablo-UA%2FDSC_9345.jpg&hash=e2a9b0cf09a01b8b2ec8f463622aec61)
![[IMG]](proxy.php?image=http%3A%2F%2Fi48.photobucket.com%2Falbums%2Ff237%2FPablo-UA%2FDSC_9343.jpg&hash=b812df363053403d8b3df0372f377520)
![[IMG]](proxy.php?image=http%3A%2F%2Fi48.photobucket.com%2Falbums%2Ff237%2FPablo-UA%2FTighteninginstructionsforcylinderheadbolts.jpg&hash=b1e66847bc5d98b2965c9485ed88bde2)
![[IMG]](proxy.php?image=http%3A%2F%2Fi48.photobucket.com%2Falbums%2Ff237%2FPablo-UA%2FRemove_installcylinderhead-00002.jpg&hash=49c9d483be6c0a30febf8c3f1f7ac55d)
