Meritor 10 speed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bent Wrench, Feb 2, 2011.
  1. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Izza Meritor 10 speed wortha crap? It's in a 97 Shaker behind a Kitty. This isn't one of those input shaft breakers is it?
    I read some static somewhere that the Range selector is electric and funky?
  3. niceguypmp3
    niceguypmp3 Bobtail Member
    43
    8
    Aug 31, 2009
    Weldon, IA
    We have 4 '03 FL with the Meritor 10 speed and 435 hp C-15 with mileages anywhere from 525k to 870k. We haven't had any trouble with the tranny's at all. Interestingly enough, off the top of my head I can't remember if the Range selector is air or electric. I guess I haven't ever tried to shift ranges before the air builds up lol. Maybe someone else will chime in. I hope they are a good tranny, we've only had a little over a year of experience with the 4 we have.
  4. DedHedEd
    DedHedEd Light Load Member
    151
    70
    Dec 20, 2010
    TulsaTown, OK.
    The only problem I had with a Meritor is the synchronization, or sumthin' sorta funky, that often 'clipped' gears and at the end of the day your right hand ended up hurtin' a bit!! I NEVER had that problem with a Fuller 10-speed, only the Meritor. Ask any Crete driver,,,they'll tell ya! :biggrin_25520:
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I would like Eaton 13to ore European ZF (16st). easier to get parts here
  6. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    what model # is the trans or the last 6 of your vin? meritor uses snap rings to hold their gears in place. i have seen the snap ring get pushed out of the gear by forcing trans into gear. then trans will stay in the gear.
