Meritor axle flange nut torque.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 3, 2020.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I have 40000 lb Meritor rears in my truck I think they are RT 140?
    I am looking for what to torque the axle flange nuts.
    They take a 15/16 socket so they should be a 5/8 fine threaded nut.
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    185-205ft lbs.
    1/2 in air impact will usually get you right in the ballpark.
  4. Dino soar
    4,815
    27,071
    Dec 8, 2017
    I may not have had the right Spec for them the first time.
    On one wheel the nuts actually came loose and luckily I didn't lose much oil until I caught it.
    Maybe I should put regular self-locking nuts on them?
    Mine are the type that has a nut with the washer behind it but I don't have the cones.
  5. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    If they loosened I most certainly would use new locknuts. Though reuse is typical with no issues. Tighten in a star pattern just like a wheel. Hitting each nut atleast twice to be sure its torqued evenly.
    spsauerland and Dino soar Thank this.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    On the Meritor without locknuts, we always put blue threadlocker on the stud in the Army.
    Dino soar Thanks this.
  7. Dino soar
    4,815
    27,071
    Dec 8, 2017
    What is on there right now they are not lock nuts they're just nuts with washers.
    I have a place near me that I can get the actual cone lock nuts I don't know if they have that exact thread in a cone or if they have it in a flange nut.
    Would either be okay and do I still use the washer?
    I did clean the nuts and the studs I could put threadlocker on them.
