Meritor unitized bearing help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by circle h, Jul 6, 2021.
  1. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    I have an Ff983LX10 meritor front axle with unitized bearings. It needs wheel bearings. You can only buy them from Kenworth with permission from Paccar if it's an "emergency". Personally if I can grab the top of a tire and move it a half an inch in and out I would think it qualifies. Has anyone successfully rebuilt one of these? Or does anyone know of another solution? The axles spacing at 32.5 inch with a 5" drop makes it so there is nothing in the wrecking yards. Thanks for any help.
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Find part number on this hub and check with CONMET ConMet Wheel End App
    Dino soar Thanks this.
  4. 062
    062 Road Train Member
    6,324
    33,961
    Oct 20, 2013
    If you have a part number call around. Odds are you can find it.
    International wanted $750 for a condenser and I found one 90 miles away for $260 at another dealer.
  5. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Experience with them better check spindle for damage. Worst #### thing on a truck. Along with all the sealed components. Fleets are to ####ing cheap to maintain equipment. So we get stuck with the ########.
  6. circle h
    240
    375
    Oct 22, 2020
    Okay, I cannot thank you enough. I just looked them up on Conmet and I believe they can do them for cheap in comparison. I will call them in the AM.
    Snailexpress Thanks this.
  7. Dino soar
    Dino soar Road Train Member
    4,815
    27,068
    Dec 8, 2017
    I would recommend that you find the crossover for a regular Hub with regular bearings that you can service.
    If you service them correctly and you have the play set correctly, it's astonishing how long bearings can last. And your hub.
