Minimum equipment for taking Class A test?
Discussion in 'Trucking Schools and CDL Training Forum' started by gkmissingca, Dec 12, 2017.
  1. gkmissingca
    gkmissingca Light Load Member
    102
    29
    Feb 18, 2017
    Could you take the test in a Dodge dually with a 20k GVWR wedge trailer?
  3. lagging
    lagging Medium Load Member
    520
    306
    Aug 27, 2016
    Atlanta Ga
    Yeah and have air brakes and no semi restrictions
    cmrdev Thanks this.
  4. cmrdev
    cmrdev Medium Load Member
    370
    373
    Oct 13, 2017
    AS LAgging said, You will have airbrake restriction and No Semi restriction. Also, there is a restriction now that restricts you to automatic trans if that's what you take the test in. All 3 restrictions would require you to retake the exam in an actual big rig and not a pickup truck. I doubt you were thinking that you could sneak a true class A with that set up though right?
    x1Heavy Thanks this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    I agree with the others.
    Get a actual 18 wheeler, a full blooded manual transmission truck.
  6. gkmissingca
    102
    29
    Feb 18, 2017
    Well, I currently have a class B with air, tanker, manual, but thought I would ask
  7. cmrdev
    370
    373
    Oct 13, 2017
    YEah even if you showed up to take test in a class b air brake truck with a 10 ton trailer, you would still get semi restriction on class A. In order to not have the restriction, it must be a tractor with 5th wheel. It wasn't but a few years ago where many people would just show up with a big dump truck w/ automatic trans and a tag a long trailer and get class A with no restrictions.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    What do you mean by semi restriction? That's not a feleral guideline, or state of Michigan restriction. There is a no 5th wheel restriction if that setup used a gooseneck.
    Drivers
  9. cmrdev
    370
    373
    Oct 13, 2017
    IF the driver wants air brakes and no semi restriction, He will have to step up to an air brakes tractor with a fifth wheel to take the test. That would be a semi truck. So yes it is a federal guideline. On the back of your license will say "O" No semi
    He can get a class A with his gooseneck but with that setup, it will have several restrictions. ITs unclear what he was wanting the class A for
  10. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    An O restriction is simply a 5th wheel restriction. Look at the link I gave.
    The op didn't say if that setup was a gooseneck or a 5th wheel. If it was a 5th wheel on the pickup, his only restriction would be air brakes (and maybe auto tranny)
  11. gkmissingca
    102
    29
    Feb 18, 2017
    Ok, one more question. If the truck is air, but the trailer is electric, will I retain the air on my license?
