Mirror Ground Wire
Discussion in 'CB Radio Forum' started by awright, Dec 22, 2020.
  1. awright
    awright Light Load Member
    86
    16
    Dec 20, 2016
    Does anyone know if the mirror ground wire is good, as long as it will light a test light off of the batteries? I am struggling with a high SWR, and wonder if I need to re do the grounding on the mirror arm.
    Thanks
  3. Finfn1372
    Finfn1372 Road Train Member
    1,930
    3,599
    Aug 7, 2014
    Greenville,NC
    What kind of truck.
    I had an issue on my volvo,until I put some good studs up.
  4. awright
    86
    16
    Dec 20, 2016
    its a 2006 peterbilt 379. Something in my SWR has changed, and my antenna and coax test ok.
  5. Finfn1372
    1,930
    3,599
    Aug 7, 2014
    Greenville,NC
    Hopefully someone can come in and help you.
    I'd suggest maybe running a ground strap.
    Timin770 Thanks this.
  6. awright
    86
    16
    Dec 20, 2016
    Yes, that is what I plan to do when I get back to the shop. Thanks
  7. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    What kinda numbers are we looking at?
  8. awright
    86
    16
    Dec 20, 2016
    I am getting 2.5 on channel 1, and 3.25 on channel 40. Way too high, and I have the stinger all the way in on a 4 foot fiberglass firestick antenna. I am in the market for a new antenna, since my Wilson 5000 broke, I just have not made a decision on what to go with this time. Predator 10k, Stryker, or another wilson 5000. I have to figure out this swr issue first.
  9. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    I'm still chewing on the SWR issue, but I'd recommend getting a 5-footer if it fits under bridges. That extra foot makes a big difference
  10. Ridgeline
    22,717
    123,128
    What are you getting at the antenna?
  11. awright
    86
    16
    Dec 20, 2016
    The SWR is running about the same at both locations. I have put in line behind the radio, and also before the antenna. I tested the coax, and it is .2 Oms resistance, so it seems to be ok. I don't know if there is a test for the mirror ground, other that if it will light a test light or not. When I get back in the shop, I think I will redo all the ground wires and see what i get.
