More ISX fun
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 4x4_Welder, Dec 11, 2014.
  1. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    One of the trucks decided to act up again last night, 2011 KW T800 with an ISX. I ran it for a bit, it didn't sound quite right, the clatter was much quieter but there was noticeable valvetrain noise. Driver says it pulls just fine, but the engine light is on (engine and wrench). The truck had runs to do, so it went out after I pulled the codes. I got:
    4364-18, SCR efficiency
    723-7, Cam/Crank sensor mechanical misalignment.
    With the engine still running, is this likely a sensor failure, or can these engines actually jump time? It only has about 130k on it, and for at least the last six months has been getting the oil changed every 10k.
    Tomorrow I am planning on popping the cam cover off to see if there's anything visible going on, I know the older engines had cam material issues and rocker issues, but that wouldn't throw codes like this, right?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Just buy sensors an with 1 bolt replace both sensors after you insp. cam + rocker arms,
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    There is enough backlash in the gear train to cause the timing codes when the engine is bucking and kicking or running rough. This can be cause directly from the sensors or other issues like fuel or injector issues.
  5. uvulabruzr
    uvulabruzr Bobtail Member
    36
    13
    Nov 1, 2014
    CANADA...EH
    if you have an engine serial # I will check out quickserve and let you know what it says
