More Problems With 4-Wheeler CB
Discussion in 'CB Radio Forum' started by RadarRider, Nov 29, 2010.
  1. RadarRider
    RadarRider Bobtail Member
    7
    Smithfield, RI
    I finished hooking up my Cobra 29 to my F-250 diesel, & I'm having some problems. It's nothing like my rig when you just hook it up to the red/black posts & you're off, right? Anyway, I originally hooked the CB up to the driver's batt. When I turn the radio on with the truck running, everything seems fine until I key the mic. When I do, the idle seems to drop down like the batts are being drained but the truck doesn't die. I release the mic & the idle goes back to normal. Just to see what happens, I put the ground for the CB on the other batt ground & it's slightly better, but I know this shouldn't happen.
    I threw my multimeter on the batts with the truck running. With the radio on or off, it charges # 13.58-13.6v. When I key the mic, it drops between 13.4-13.44v & doesn't go beyond that until I release the mic. I turn the radio off while the trucks running & it still charges # 13.6.
    I know this has to be something stupid I'm overlooking. I've had many CBs in Rigs & 4-wheelers almost all my life & this is the 1st time I've seen this. I even had a Cobra hooked up to an '87 Chevy C-10 with one 6yr old batt the same way & never had this problem. Can anyone help?
  3. Chain Drive
    Chain Drive Medium Load Member
    436
    113
    Nov 28, 2008
    Nova Scotia,Canada
    sounds like a bad connection somewhere, not necessarily with the C.B. hook up, I just put a Magnum in my KW and when I yelled into the mic the truck cut out, turned out to be a bad ignition switch, it just took that little bit of extra draw to show the problem, try hooking up an inverter or a few extra lights to see if it does the same thing
  4. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Your computer is picking up the CB A friend had a GEO-METRO that did the same thing.
  5. Chain Drive
    436
    113
    Nov 28, 2008
    Nova Scotia,Canada
    pls elaborate is there a fix?
  6. RadarRider
    7
    Smithfield, RI
    Yes, please! I'd like to know so I can enjoy both my truck & CB.
  7. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Usually you won't see that kind of problem running a stock CB Radio...Usually You would see the motor getting pulled down when also running a Amp, or maybe one of the High Dollar-High watt Export radios like a Galaxy 98 or some of the Magnums...
    I doubt a stock Cobra 29 could cause enough RF to get into the trucks computer either.
    What I would do, is run your hot wire off the CB to the positive terminal on your battery, and then the Ground off the CB to the frame. (for starters) And maybe use 8 gage wire...farther the run of wire from the CB to the battery, you don't want to be using some thin wire...
    A Ford F250 should have more than enough power to run a Cobra 29 without pulling down the motor or causing a noticeable drop in voltage. A drop from 13.6v to 13.4v is not enough of a drop of volts to do anything...There's just no-way a drop of just .2 volts could cause the motor to act-up...Or even dim the lights!
  8. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Bill had a early 90's GEO-Metro even a stock 148 running 4 watts watts got into his computer and changed the motor speed.........
    GM's answer was to remove the radio ..........
    He got rid of that car bought a small ford .... no more radio problems .....
    I run 100 watts in my Corolla no problems ....
  9. dodge24v
    dodge24v Light Load Member
    99
    34
    Nov 21, 2010
    VA
    Yep, the CB is emitting electrical noise through the battery.
    The only way to get rid of it is to run an RF noise isolator between the battery and CB.
    I've seen alot of these problems while in the navy working on small boat HF, and VHF radio's.
  10. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Yeah but your talking about a dang Geo vs a F250...And a stock 4w Cobra 29...I don't see the radio being a problem as long as it's wired up right and the antenna is tuned.
  11. Flying Finn
    Flying Finn Heavy Load Member
    972
    558
    Jun 22, 2010
    Ontario, Canada
    Simple fix. test and repair or replace your alternator. If you are running and only getting 13.6V at the battery then you are not charging properly. The alternator is weak, the diesel is drawing more of it's power from the batteries in order to run. Whereas the alternator should be producing it all. If you disconnect one of the battery terminals when the truck is running I will hazard a guess that the truck will stall.
    Charging voltage should be at 14.1V. Fully charged batteries, no load, truck not running should read right about 13.6v.
    Simple fix, do it NOW before you kill your batteries and end up paying for a tow, two new batteries, and an alternator.
