Driving in the mountains advice for new drivers.
Discussion in 'Questions From New Drivers' started by cbones98, Oct 17, 2024.
  1. cbones98
    cbones98 Bobtail Member
    15
    18
    Jun 21, 2022
    Im a midwest guy just getting his feet wet for the first time out here in the mountians of Colorado. I've driven Hwy 6 and Hwy 40 and so far I feel like ive done ok except for the fact that I believe I glazed my breaks a bit due to my jakes not kicking in until 35 mph which made me take a few spots faster than I would have liked. This leads me to ask all the old timers and regular mountain drivers their best advice for traversing steep terrain but my real burning question is how did they do it before disc breaks and jakes?! I mean really I would think anything above a 6% grade for more than a few miles would just be a death sentence without jakes at the least. Is the secret really just going slow as molasses? If your gears to low you have to keep breaking to keep your rpms low and to high it'l want to run away on ya.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,011
    2,077
    Dec 15, 2021
    If your driving a manual, go down in a gear or 2 under than the one you climbed with.If you're in an auto,switch it to manual and do the same thing.Watch your rpms and don't let it get too high.
    Use some brakes and downshift if you're going a little faster than you want .It takes some practice and experience.
  4. cbones98
    15
    18
    Jun 21, 2022
    Thanks. Im in a 13 speed. I feel like it would have been much easier if my jakes kicked in at 15 or 20 and not 35. The mechanic said he'd change it when I get back.
  5. Kenworth6969
    2,980
    9,332
    Jul 3, 2020
    It's real fun going down the mountain and you hit ice and snow :eek:
  6. Big Road Skateboard
    7,055
    39,954
    May 2, 2021
    Speed is key. You can have jake settings reset to lower mph.
    A buddy runs a 12 Volvo with a D16. He says the engine brake is so effective, he'll run down 6%'ers at 70, and the brake will slow him down easy. Never touching his brakes.
    His engine brake quit two weeks ago, and he about lost it droppin down from Parleys Summit.
    I drive an older truck with a Jake that's nothing like newer trucks.
    6% and loaded, i come down around 30mph. I like keeping RPM's below 15-1600 RPM with the jake on especially in inclement weather.
    I've gone up and down grades up to 10% loaded with no issue.
    I try to stay below 20mph 7% or over
  7. bryan21384
    bryan21384 Road Train Member
    15,686
    34,147
    Sep 18, 2009
    Memphis, TN
    Rule of thumb....the gear you go up in, you need to use that gear or a lower gear to go down. The heavier you are, the lower the gear. Also, don't get caught up in what some of the other idiots are doing, many will fly down mountains. Be patient an take it slow.
  8. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Yes.
    Theres 3 methods without jakes
    1. "hopes and prayers", this smokes your brakes every time you dont rollover
    2. Get in a gear where you can use 20-30psi brake application pressure to go 5 mph above amd then below your prefered speed, (ie target 20 mph, be in the right gear for it, when it hits 25, slow down to 15mph, let it go back up this mostly works, but on very long grades will smoke your brakes
    3. Be in the right gear to hold your speed or lower with 0-10 psi brake application pressure steady, no speedup, no slowdown, ie, 20 mph, it speeds up at all, you apply up to 10 psi pressure, if that doesnt bring you down to 20 mph, you are either in too high a gear or targeting too fast of a speed. If you can keep it below 10 psi, its unlikely youll ever smoke your brakes. Did 0 jakes like that through pa with my 9 speed, worked a charm, gutless going up a hill and stupid slow going down
    For determining speed for the gear, for method 2 and 3, you want to be at peak torque for your engine +100 rpm (so for my 3406e, torque peaks at 1250, so 1350), too far above that point you will get to runaway, too far below that, the engine cant hold you back.
    By adding in jakes, all you do is go up a gear or two (or4), theyre nice to have but not neccessary, can go a bit higher on the rpms, but too far still puts you in a runaway position
    Also, what do you mean jakes wont work under 35 mph? Thats just not factually correct, or if it is, whoever put that limiter in was an idiot. Jake applications should be limited by too low an rpm, not a speed of vehicle, i have descended a long twisty mountain in co just using jakes and 4th gear (13 spd) to hold me steady at 12 mph for about 3 miles.
    Turn your cruise off or tap your brake, jakes should engage down to at least 1000 rpm, much lower than that they can stall the engine
  9. 201
    201 Road Train Member
    12,744
    26,206
    Apr 16, 2014
    high plains colorado
    Welcome to Colorado and to the site.:hello2: I did the same thing almost 7 years ago from the Badger, and never looked back. If you haven't run Hy. 50, that cuts the state in half, it's a great bypass to go around Denver, if you can stomach Monarch Pass, you can do anything. We never had brake scorching hills in the Badger, and the utmost concern here is speed. I've heard old timers out here would crest a hill at a crawl. It was a lot easier to speed up than try and slow down. We never had engine brakes, so proper gear selection was essential. The same is true today. If you find yourself going too fast, several methods are used, the "mash 'em hard" to slow before overheating the brakes, or the "stab and release", aka, panic mode. The passes require finesse, and CDOT does an excellent job, but can be overwhelmed pretty quick. Readouts on your "info gizmo" should alert you of pass closures, and not sure you can "hang iron", but better learn, as there are big fines for not doing so. We have our 1st snowfall in the hills for this weekend, I'm sure I-70 will be affected too. I've found, people in Colorado are pretty cool, and will do their darndest to help.
  10. snicrep
    snicrep Road Train Member
    1,366
    2,548
    May 13, 2009
    mcallen, tx
    I see your problem. You're spelling " brakes" wrong.
  11. cbones98
    15
    18
    Jun 21, 2022
    This is gold. Anyone getting ready to go through the mountians should know this before they even leave. And no the jakes work below 35 but they will not kick on UNTIL you hit 35. So ive had to get it in 6 lo, let it run up to 35, and spike the breaks where it levels out to try to drop a gear. I am in a brand new kenworth t680 and yea this things tuned fine for running in and out of Detroit where im from but not for these mountians. When I get back the mechanic said he was gonna tune it and change the speed to activate the jakes to 15.
