MX-13 Boost Issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mid-Island, Jun 18, 2022.
  1. Mid-Island
    Mid-Island Bobtail Member
    Hoping someone can help.
    I have a 2015 Peterbilt 389 with Paccar mx13 that will not build boost past 19 psi..
    When I start the truck the exhaust is clean....
    When i leave the yard the exhaust stays clean until i hit high gears and the engine is asking for torque.... once that happens the boost gets pinned at 19psi and it starts smoking like crazy.
    Limp back home and no smoke.
    I Opened the turbo and found fins broken so i swapped the turbo and the actuator for a brand new one and took it for a test drive and its doing the exact same thing.
    Any help would be greatly appreciated.
  3. Arctic_fox
    4,461
    24,996
    Sep 16, 2016
    Check the EGR valve actuators. They got sticky on mine and wouldnt open all the way and i had to get it cleaned to unbork the problem. Also if the EGR has not been cleaned in a while have it pulled, cleaned and inspected as a whole. Lastly have your system tested for leaks. Sometimes the metal elbows or even hoses wear out and crack.
    Mid-Island Thanks this.
  4. Mid-Island
    New things to try...! I will report back after...
  5. Goodysnap
    Goodysnap Road Train Member
    3,760
    9,165
    Jul 12, 2017
    Start with engine management EGR/ cleaning. Boost sensor, before and after bpv pressure sensors are all common to plug with soot.
    spsauerland Thanks this.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Sounds deleted??? Those tend to plug the exhaust pressure sensor before turbine tube.
    Goodysnap Thanks this.
