Mx13 boost stuck at 14.4
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ColumbiaBoB, Dec 4, 2024.
  1. ColumbiaBoB
    ColumbiaBoB Light Load Member
    190
    21
    May 3, 2011
    Des Moines, IA
    Hi, i have 2020 kenworth with mx13, bought the truck about a month ago. Just got OTR performance scanner and boost is stuck at 14.3-14.4, idle or driving, no error codes what could be the issue. TY
  3. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    First, what caused you to use the scanner? Is the truck not performing well?
    Can you plug the scanner into another truck and see if it changes? You may have a scanner issue.
  4. ColumbiaBoB
    190
    21
    May 3, 2011
    Des Moines, IA
    It can read/clear codes do forced regen, just so i can keep an eye on stuff
  5. Arctic_fox
    4,508
    25,450
    Sep 16, 2016
    Is your truck deleted?
  6. ColumbiaBoB
    190
    21
    May 3, 2011
    Des Moines, IA
    No
  7. ColumbiaBoB
    190
    21
    May 3, 2011
    Des Moines, IA
    No
  8. Arctic_fox
    4,508
    25,450
    Sep 16, 2016
    Had to ask. One of the budget deletes messes with a file that causes the truck to get stuck with high boost more or less exactly like that. Odds are good its a scanner issue then.
    Deezl Smoke and ColumbiaBoB Thank this.
  9. 062
    062 Road Train Member
    6,327
    33,967
    Oct 20, 2013
    You sure that’s the boost psi reading?
    Barometric pressure is going to be around 14psi at all times.
    @Goodysnap
    MAMservices and Oxbow Thank this.
  10. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Do you mean the reading in the diagnostic tool is stuck at 14.
    With no power complaints or related faults , this is an issue with the tool.
