MX13 Holset turbo oil seepage
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Brandonpdx, Jan 24, 2026.
  1. Brandonpdx
    Brandonpdx Road Train Member
    4,706
    4,811
    Dec 27, 2007
    Elkhart, IN
    I started noticing this oil seepage around the bottom here where the oil line connects to it. Is this a clue the turbo is on its way out or is it maybe just a cold weather leak that need fixed? I started noticing it back around December when the weather got cold. Turbo itself and the exhaust brake seems to be working fine. (I don’t know if that pressurized oil line has anything to do with the VGT or turbo brake function or if it’s strictly for lubricating the center section.) You can see it’s been pissing little droplets onto the frame rail. It’s due to go in for a PM anyway but thought I’d ask if anybody else has seen this one. EPA 2013 engine and I think it an “HE500VG” model Holset turbo they want $8000 for a new one.
    2B9BD74E-7867-4E81-8D22-226FED60096A.jpeg 658B8F01-0A30-4942-820E-F9BBA68C25CF.jpeg 7E6AB034-EDBC-48A2-AD07-DEBC4803A316.jpeg
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,082
    Dec 15, 2021
    Should be an O ring on the fitting.
    I've got a 2021 ,turbo is different,but I just cleaned it off with brakeleen and put a new O ring in,the old O ring was brittle.
    O ring was $2.09 at Kenworth.I think the larger O ring was $9.00.
    Brandonpdx Thanks this.
  4. North Pole Nightmare
    1,013
    2,082
    Dec 15, 2021
    If the braided part of the line is leaking just replace the oil line.
  5. Brandonpdx
    4,706
    4,811
    Dec 27, 2007
    Elkhart, IN
    That might be a good idea anyway.
