MX13, now what?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bonder45, Feb 23, 2021.
  1. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    Well I added another truck to my collection.
    No smart ars responses to this about, “should of bought this, blah, blah that” I bought this, it was a good deal.
    I always like to change as much as I can before I put her to work - given I know little about Paccar MX13 engine what should I be doing?
    - engine oil and filters
    - fuel filters
    - get DEF filter cleaned ( maybe ? )
    - cabin and air filters
    ADDED
    • clean EGR cooler
    • Clean DPF filter
    • Valve adjustment
    • DEF dozer clean ( run DAVIE4 forced regen )
    • Clean boost pressure sensor
    • Clean EGR pressure sensor
    • Clean DPF differential pressure sensor
    .....still currently doing research and reading up on this engine as I post this thread.
    ( 510 HP / 1850 TQ, 18 speed, super 40 rears )
    D.Tibbitt Thanks this.
  3. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    I’m a company guy so I can’t help much but I’ve been driving paccars for the last 3 years. They pull like slugs but they’re good on fuel if you spec them right and drive it right. They do not like idling long you should get an apu with it or have your own generator rigged in cause if you idle long it’s going to be in the shop ALOT. All the power is between 1250-1500 after you can feel the torque going down.
    joseph1853 Thanks this.
  4. bonder45
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    I have a strict no idle policy with my guys.
    Also have a Maxxforce so I know all about no power ....hahah
  5. Ffx95
    1,370
    2,635
    May 18, 2017
    Oh also the fuel filters are even finer they filter on smaller microns (I think 8 microns) then the freight shakers so your drivers have to keep an eye on the fuel water separators they need changing more often especially in the winter.
    Accidental Trucker Thanks this.
  6. Cat sdp
    Cat sdp . .
    21,279
    76,004
    Apr 8, 2012
    Orion's Belt
    If you have to pull the cam out the entire engine needs to come out first.........
  7. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Nox sensor were the main issues I had and random ghost codes that didn’t affect anything . When the def is overfilled it can throw a poor def quality code sometimes. Tell drivers to stop when it clicks don’t round off to a even number.
    Ffx95 Thanks this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,769
    9,190
    Jul 12, 2017
    Truck model, Year, miles and hours?
    If n you dont have any history on the truck. Yes, to all you have mentioned.
    Getting hooked up and looking at some reports could tell you if the aftertreatment is healthy status or not.
  9. bonder45
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    2015 Kenworth T680
    400,000 M
    12,000 hours
    Trucker61016 Thanks this.
  10. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    I ran a 2013 (MX 13 epa 10 model) to almost 1 million miles and never rarely had a issue. Don’t idle the engine long term do the required maintenance and they are a good engine. Don’t let the Cummins fan boys get you down. Cummins has #### engines also
  11. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    When maintaining your MX,don't forget too change the airdryer cartridge.
    They are cheap.
    jason6541 Thanks this.
