my back hurts...
Discussion in 'Experienced Truckers' Advice' started by TruckerPete1990, Apr 4, 2013.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    So I've had back problems for some time. After about 30mins of sittin in seat my lower back starts hurting. My last truck didn't have this problem to much. Now this truck I do. Only way I get pain to stop is to use my sweatshirt. Any tips be great.
  3. rogueunh
    rogueunh Road Train Member
    1,086
    23,033
    Jan 4, 2011
    I roll up a light jacket or fleece, and stuff it behind my lower back. My seat has lumbar support that inflates, but it just isn't enough.
    TruckerPete1990 Thanks this.
  4. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    I know truck stops sell those back supports but Idk if they work or not lol
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    I put extry foam in my seat back. It had a square cut out in the one-piece back for some stiffer foam at the lumbar area. I put some thicker, stiffer stuff in there and now I have a good 3" of firm lumbar support. It did wonders for my back. However, it is non adjustable but it's a small price to pay for a better back.
    I did some research online about lumbar support and the max doctors seemed to use was 3" and that was for crippled folks with back trouble so I imagine anything more would be not good.
    My mantra is proved once again - "if you want something done right, do it yourself."
  6. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    Check and see if your seat has a "railroad setting". I'm sorry, IDK if it has another name. This setting allows the seat to slide forward and back about 1" while in motion and takes out a ton of the minor impacts from road bumps. Once I engaged that setting my back pain went down a lot.
  7. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    My lower back pain comes and goes but I use a memory foam pillow the same kind you would normally put under you head to sleep. Most are contoured almost like a wedge and I put that on my seat and it sits nice on my lower back. My Chiro' wanted $95 for the same think I got at Wally World for $22.
  8. DirtyBob
    DirtyBob Road Train Member
    1,913
    1,628
    Sep 2, 2010
    Indiana
    Do some stretches before, during and after a shift. I scoffed at the idea at first but it's made a difference for me. Even use rubberbands to help with shoulders.
    randal02lee and TruckerPete1990 Thank this.
  9. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    Sounds chronic go see a chiropractor u wont loose anything.
  10. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    I also had some back problems starting a couple of months ago. The solution for me was to adjust the height of the seat DOWN so that my heels are pretty firmly on the ground AND to spend a fair amount of time (about half) driving leaning forward over the steering wheel. The forward leaning position helps stretch the lower back and takes pressure off it. I also concentrate on NOT slouching in the seat (although I catch myself slouching at times). Also try occasionally lifting your legs as if you are running to tighten your abdominal muscles and other exercises while driving, this has the added benefit of helping to keep you alert.
  11. DirtyBob
    1,913
    1,628
    Sep 2, 2010
    Indiana
    That's one of my biggest problems. I catch myself doing it constantly. I'm hoping one day I just sit up straight naturally and don't have to tell myself not to slouch, but I'm definitely not there now.
