1. Tyson509
    Tyson509 Bobtail Member
    Have a N-14 water in oil what is the problem
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    Failed oil cooler
    leaking cylinder liners
    air compressor
    injector cups
    head gasket
    ShooterK2 Thanks this.
  4. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Exactly. Oil cooler would be where I would start.
  5. Goodysnap
    Goodysnap Road Train Member
    3,767
    9,187
    Jul 12, 2017
    How bout' dropping the pan and pressurizing the cooling system? That's where I would begin. Why guess?
  6. Dexx69
    Dexx69 Bobtail Member
    28
    5
    Mar 14, 2012
    Swanton,vt
    oil cooler failure will put oil in the coolant due to the pressure difference, not the other way around.. but definitely drop the pan, do thetpressure test..so you don't waste your money like I just did with my isx. Currently scratching our heads on this one.
  7. Heavyd
    7,826
    6,275
    Feb 4, 2009
    Dex, coolers can fail in such a way that when the engine is running and oil under pressure the oil doesn't leak into the coolant, but when shut down the coolant is hot and still under pressure and can leak into the oil.
    Klleetrucking and Goodysnap Thank this.
