N13 Navistar
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Utlitiestech, Aug 30, 2023.
  1. Utlitiestech
    Utlitiestech Bobtail Member
    6
    Aug 30, 2023
    Good evening I have a 2016 n13 that will only Regen if you pull to the side of the road and use the switch on the dash. It will not automatically do a regen
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    I would be thankful it will do that and rock on.
  4. Utlitiestech
    6
    Aug 30, 2023
    Yes sir but it’s not correct and it needs to be fixed I’ve tried to do a search and can’t really find information on it I’m hopeful someone in here can possibly point me in the correct direction
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    How do you it isn't regenning when you are driving? There are no driver indicators that it is regenning on its own unless you are driving less than 5 mph and the high exhaust temp light is on.
    IH9300SBA Thanks this.
  6. Utlitiestech
    6
    Aug 30, 2023
    Because the display tells you to pull over to do a park regen it will not do it while driving
  7. Heavyd
    7,826
    6,275
    Feb 4, 2009
    Do you ever see the high exhaust temp light when moving under 5 mph?
  8. Jesh574
    Jesh574 Bobtail Member
    8
    6
    Jul 26, 2023
    Alaska
    How is this truck normally driven? City traffic, highway, heavy loads, how would you describe it? The engine has to be worked hard enough to get up to temp for passive regeneration to occur.
