N14 Cam Replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by truckinhermit, Dec 15, 2021.
  1. truckinhermit
    truckinhermit Bobtail Member
    28
    19
    Sep 12, 2021
    I'm currently in Phoenix. I can't find a single person to help. The threat of me going out of business within the first year and getting this truck back together is definitely looming within the next few days.
    What tools are required to pull the Cam? I've already got it down to the accessory drive that I can't pull. I'm getting a jack in the morning but I'm trying everything I can to stay in business. Seems no one here in Phoenix cares.
  3. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    I don't have an N14 I have a Big Cam but I would imagine they are about the same.
    I don't think you really need any special tools to pull the camshaft out but you have to take everything off of the front and be able to remove the front cover... Except if you have to remove the accessory drive gear or if you are going to change the cam bearings.
    You also have to be able to back off on the valves and remove the push rods.
    Normally you remove the cam followers but if you have coat hangers or strong wire, you may be able to tie the cam followers up away from the camshaft.
    I don't recall whether the camshaft will come out with the accessory drive gear on or not. It may come out right past that gear without taking it off. I seem to recall that Camshaft gear is pretty big I would think you can leave the accessory drive as it is.
    If you can't get it past the accessory drive gear then you need a puller to get it off and you need a special tool to put it back on. You will need a new rubber seal that fits in the slot and you will need a new nut. Whatever you do, do not try to put the accessory drive gear on with the nut, you need the special tool. And a torque wrench. I think the accessory drive nut is somewhere around 300 pounds, I'd have to check my manual.
    If you can hold the cam followers up I don't think you have to actually remove the accessory drive itself.
    Also if you don't disturb the cam followers by not removing them, your timing will remain the same and you will not have to retime it.
    If you are going to replace the camshaft bearings there is a special tool they sell to remove them but you'd have to have the cam followers out to do that.
    Then you would need the tool to time the engine or someone to time it for you.
    I'm not sure what tool you need to set the STC injectors because my injectors are different.
    If you need to remove the whole accessory drive the bolts on the back side of it you can use either a very short wrench or a wrench that you cut down or they sell a wrench that's kind of bent like a 1/2 moon.
  4. truckinhermit
    28
    19
    Sep 12, 2021
    Cam is bad. So are rollers on the followers. Accessory drive has to come out as well as the gear.
    Rideandrepair Thanks this.
  5. xsetra
    xsetra Road Train Member
    5,195
    7,145
    Aug 21, 2011
    My cam went bad in June. Shop said metal flakes went everywhere oil flowed. I put a new motor and every component the oil flowed thru.
    Wish you the best.
    Rideandrepair and little cat 500 Thank this.
  6. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    Go here... Cummins QuickServe Online
    Create an Account (it's Free) Register your ESN.& you will have access to Parts books & Manuals applicable for your Engine..
    Good Luck..
    Rideandrepair, Coffey and BoxCarKidd Thank this.
  7. haycarter
    1,920
    5,317
    Jun 9, 2012
    Australia
    delete double post.
  8. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Why can't you pull the accessory drive?
    Some C wrenches, like a Snap On M1321, are needed to get the compressor off. Pulley comes of with a regular flange type puller
    Here's the pulley installer:
    M20020 Cummins Accessory Drive Pulley Installer 3376085
    It's probably not that Phoenix doesn't care, they just don't know. Kids in the shop don't know much about older engines. I gave up trying to find someone to rebuild my big cam and just did it myself
    The hardest part for me to find in the rebuild was cam follower pivots. I'd recommend getting rebuilt cam followers if you find you need to replace those
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,547
    6,638
    Aug 26, 2014
    Is this an STC or an electronic injector engine?
  10. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    When we ran trucks we broke down in Phoenix one time and they stuck it to us real good at the shop we ended up at. And they took their time for something simple. Can't remember the name. Maybe Lake something. It was probably 15 years ago.
  11. truckinhermit
    28
    19
    Sep 12, 2021
    Got the Cam out, last rebuilds timing was bad. Pushed Cam over in the bearings and ate up the Cam. Bearings are coming out with new being put in other then the 7th. 7th isn't that bad.
    Just leaves timing which may be difficult to find someone to do in Phoenix.
  12. BoxCarKidd
    4,547
    6,638
    Aug 26, 2014
    How does incorrect camshaft timing eat cam bearings? Did it run OK?
