N14 Celect + CPL Headaches
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by NebraskaGMC, Oct 20, 2024.
  1. NebraskaGMC
    NebraskaGMC Bobtail Member
    37
    13
    Jun 9, 2019
    I'm sure this topic has been beat to hell, but I can't find any information on it that's worth anything. What I want to know is what CPL numbers were used on the 525hp N14s? I have a CPL 2391 and it's set at 525/1850 now, originally 435 and I assume 1450 because that's what the original tranny is rated for. As far as I can tell from quickserve the 2391 and the 2592 are identical, but I can't find anything as far as what they were used for. Mainly just trying to figure out with my combination of parts if I'm getting a true 525/1850 out of it or not. I know 2025 was a 525, but other than that I'm lost. Thanks in advance for any help
  3. OLDSKOOLERnWV
    19,108
    288,914
    I’ll walk out in the shop shortly and look your CPL numbers up in my book….
    broke down plumber Thanks this.
  4. DUNE-T
    DUNE-T Road Train Member
    7,041
    17,151
    May 10, 2015
    Detroit, MI
    2025 and 2592 were 525hp. 2391 had different injectors I believe.
    Go to Genuine Cummins Parts
    Plug in your esns in two different browser tabs and compare parts one by one
  5. NebraskaGMC
    37
    13
    Jun 9, 2019
    I have quickserve and that shows 2592 and 2391 being identical, injectors included
  6. DUNE-T
    7,041
    17,151
    May 10, 2015
    Detroit, MI
    Weird, I remember when I was looking for a replacement for my 2592, there was something different about 2391, but don't remember what it was exactly
  7. NebraskaGMC
    37
    13
    Jun 9, 2019
    I looked last night, 2391 and 2592 share everything, down to the cam and injectors (3411767), 2025 is the same as those two other than cam and injectors (3411763), so if the 2592 and 2025 were both 525 I assume the 2391 can put it out no problem. 2025 must just be newer why it has different parts huh?
  8. OLDSKOOLERnWV
    19,108
    288,914
    Don’t know if anything here will help but…..
    Heavyd and SmallPackage Thank this.
  9. DUNE-T
    7,041
    17,151
    May 10, 2015
    Detroit, MI
    2025 is actually the old one, they stopped making it after 2000 I believe
    NebraskaGMC Thanks this.
  10. NebraskaGMC
    37
    13
    Jun 9, 2019
    In that case, would my 2391 be a true 525 then if the 2592 was used as a factory 525 since they have all the same parts? Mine is a 1998 by the way
  11. DUNE-T
    7,041
    17,151
    May 10, 2015
    Detroit, MI
    If all parts check out I don't see why not. You can give your serial to a local Cummins dealer and see if they got a 525hp file for it.
    What's your serial btw? I am curious to look at it
