N14 celect
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jdw900, Apr 2, 2021.
  1. Jdw900
    Jdw900 Bobtail Member
    16
    4
    Jan 19, 2021
    Hope you guys can help me I have a 1992 kw W900 n14 problem is that is not boosting over 15 psi and during idle It will jump from 800 rpms to 900 but it does not do it all the time also if the I turn the truck off and on it will start boosting just fine until I get to the highest gear then it drops back to 15psi no more sometimes even lower
  3. Big Orange
    Big Orange Bobtail Member
    9
    5
    Oct 2, 2018
    If it were me I’d change fuel filters and check/ blow out the air filters first. Always start simple. Next, I’d get the ecm scanned for electrical faults. If no faults show up I would replace the fuel lines. It really sounds like a fuel feed line is collapsing and starving it for fuel once in awhile. Also- make sure the vents on the fuel tanks work. If all that checks out then you’re into the world of checking grounds and looking for chafed wiring on the engine harness- good luck!
  4. Jdw900
    16
    4
    Jan 19, 2021
    Check tps for volts and at the time that I was having issues it read 3v even with throttle fully open so I change the tps today and it still did the same thing I already change fuel filter and check lines for holes and nothing so I am guessing is going to be electrical any other advice? Thanks for the help
  5. 062
    062 Road Train Member
    6,312
    33,942
    Oct 20, 2013
    Have you load tested the power wire for the ecm?
    Confirm voltage to fuel shut off solenoid.
  6. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Don't forget this little guy..
  7. Jaebo74
    Jaebo74 Medium Load Member
    433
    1,864
    Feb 4, 2021
    Just for future knowledge, is that in the pump?
  8. Final Drive
    1,573
    2,505
    Jan 21, 2015
    Yes Sir, right next to the port were you check on pump output..
    jamespmack and Jaebo74 Thank this.
  9. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Also there is a check valve in the fuel fitting that is in the ecm cooling plate that tends to get restricted with debris. the fitting is on the outlet side of the cooler plate, remove the fuel line and the fitting and blow it out.
    mile marker 27 and jamespmack Thank this.
  10. Jaebo74
    433
    1,864
    Feb 4, 2021
    Thanks
    Final Drive Thanks this.
  11. Jdw900
    16
    4
    Jan 19, 2021
    I will check the shutoff solenoid next . I already check that little filter and is good I also check that check valve on the cooling plate and it was good l. I am thinking that if I am reciving only 3v to the sensor than it should be a problem between the ecm. Is there anything else that could fail and make the sensor get 3v ?
