N14 Cummins help!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Don 6, Aug 7, 2018.
  1. Don 6
    Don 6 Bobtail Member
    I got this 1995 international 9400i. Yesterday I was driving the truck and everything was going good and then suddenly the truck was loosing power and started chocking and black smoke was coming out of the exhaust pipes and then the truck just turned off and won't turn back on, the engine turns and won't start up. I've tried putting starting fluid on it to see if it'll start up but it takes a lot of starting fluid for the truck to start and the truck would just and die right after. Please help me out !!!!!
  3. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Sounds fuel related maybe. The ECM cooling plate has a check valve on it that may be clogged on yours. Type in n14 fuel fix on YouTube and you’ll see it. It’s free and worth a try.
    Any codes?
  4. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
    Get a meter and see if you're getting 12V out of the fuel shut off solenoid. Additionally you can take a live hot 12V and put it to that post (Remove the ECM wire first) and see if it starts
  5. william123
    william123 Bobtail Member
    4
    Mar 5, 2014
    yep, sounds like the wire to fuel shutoff valve (the wire to the post at the top of the fuel pump). also check connection of the ecm wire at the batteries.
  6. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Check the Cam Crank Position Sensor, it's located on the front lower driver's side of the engine behind the lube oil pump
    BoxCarKidd Thanks this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    How does no fuel make black smoke? Timing is or similar problem is more likely. Still should fire easy on either. Saw an 8V92 no start like that once. Had an injector plunger stuck. That cylinder must have been blowing fuel out of the fuel rail.
    snowman_w900 and AModelCat Thank this.
  8. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    Just a word of warning.
    Be careful with that ether. Always be careful with ether.
    One time a guy gave me a truck because his guys were trying to get it started and shot it with ether and they broke the crankshaft.
    It's best never to use it, but if it's truly needed you have to use the very least amount that will start it.
    tommymonza Thanks this.
  9. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Was it raining when it shut down, how long has it been between air cleaner changed??
  10. xsetra
    xsetra Road Train Member
    5,193
    7,138
    Aug 21, 2011
    Change the fuel filter.
    Check the fuel lines.
  11. Shoestring75
    Shoestring75 Bobtail Member
    7
    10
    Aug 8, 2018
    I had a c15 cat do that minus shutting off, I was messing around with it and grabbed the injector harness on the side of the head and jiggled it a bit and sure enough it stopped, broken wire, might want to check the three plugs going into the ecm you never know
