N14 dead miss
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Stevekw, Oct 6, 2016.
  1. Stevekw
    Stevekw Bobtail Member
    21
    Feb 26, 2016
    Got a 99 n14 in a W9. Few months ago it started a dead miss every so often. Like you shut the key off and on real fast. At first it would do it once a day, then cpl times a day. Now it'll go 3-4 hours and not do it, then have episodes of doing it 3-4 times a mile. No check engine light, runs fine other than this. Seems like a electrical/wiring problem to me. Any suggestions on where I should start looking? Thanks
  3. wore out
    wore out Numbered Classic
    17,309
    214,783
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    First thing I would do is put a restriction gauge in the compucheck fitting on the fuel filter. If it reads zero your sucking air. If it reads close to 9 or 10 you have way too much restriction. Check the fuel warmer behind the ECM they are bad to catch stuff and restrict flow. You can have low flow and maintain good pressure. I'm guessing it happens as you shift into high gear and hit the throttle. N14 is also bad for injector issues. If it's on the mechanical side it won't set a code. Also check all the connections for the two power fuses from the battery box to the ECM
    Stevekw and ShooterK2 Thank this.
  4. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    As always, Wore Out is right on the money. I'd also add that the injector harness can rub on the back corner of the engine (usually where the clamp is), and cause funky things like this.
    Stevekw and wore out Thank this.
  5. Stevekw
    21
    Feb 26, 2016
    It happens off and on, usually does it more when driving into a wind where there's constant throttle. But it's also done it a few times within 15 seconds of starting it up of a morning.
  6. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    I have seen a broke injector spring cause similar issue, and it wont show up in the ecm or on injector cutout test
  7. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    Ecm cables then check others?
  8. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Check the Pass Thru wires on the Injector Harness.
    Check Battery, Starter, ECM Cables and Wiring for any Chafing that could cause a Short.
  9. JDHIGGINS44
    JDHIGGINS44 Light Load Member
    113
    272
    Jun 29, 2015
    Waynesburg, PA
    Another thing you can try to isolate it down to one cylinder on an N14 is unplug 1 injector at a time on the drivers side of the head you'll see 6 matching plugs very easy to unplug one at a time with the engine running and look for the one that has no effect signalling a dead cylinder.
  10. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Fuel shutoff solenoid and the hot wire to it can cause that too. When you turn the key on should hear it click,with your hand on it,you should feel a thunk at key on. If you leave key on for a few minutes and it gets real hot,it's on it's way out.
    HopeOverMope Thanks this.
  11. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
    Second everything already mentioned, but will add check your grounds. Pay careful attention to the grounds to the ECM. Most likely corrosion inside the shield and/or a broken terminal.
