N14 No Start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OldRed98, Oct 28, 2024.
  1. OldRed98
    OldRed98 Medium Load Member
    308
    251
    Apr 18, 2017
    Colorado
    Hello,
    I have a 98 W900 with an N14 525 HP red top. It sat for a few weeks and now it wont start. It just cranks and cranks.
    When I turn the key to the on position I'm not hearing any clicks. Usually the truck does a clicking sequence. I'm assuming this is the fuel shutoff solenoid. I wanted to check on here before I buy a fuel shut off solenoid. Not sure why it would just randomly stop working.
  3. Big Road Skateboard
    7,085
    40,150
    May 2, 2021
    Sounds like you've lost ignition power to the ECM. Check ignition fuses in the fuse box, especially if it's rained.
    Without ignition power, your ABS modulators also don't click, fuel solenoid doesn't get 12V.
    Rideandrepair Thanks this.
  4. DUNE-T
    DUNE-T Road Train Member
    7,044
    17,158
    May 10, 2015
    Detroit, MI
    In my case it was harness problem that goes from batteries to the main harness and it connects behind the engine
  5. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    Does that model N14 have a thumb screw on the pressure head the solenoid is mounted too. If it does. Turn that screw in to bypass the need for 12v and manually open the fuel shutdown disk. See if it gets fuel and starts. Then you know the electric solenoid is bad or power to it.
  6. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    I think it has some relays in the battery box also.
  7. IH9300SBA
    IH9300SBA Road Train Member
    2,428
    23,921
    Feb 26, 2021
    Do the CEL & SEL cycle when you turn key on?
    Rideandrepair and Heavyd Thank this.
  8. wore out
    wore out Numbered Classic
    17,299
    214,539
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Tighten the battery cables. I know it cranks and cranks and tighten the cables sounds dumb as hell. But indulge me….I’ve seen it it time and again x 10 on some late 90’s T800’s with 365 red tops. When you hit start button the ECM loses power and she won’t hit a lick
