N14 preventive maintenance
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, May 24, 2021.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    ‘93 N14 Celect that’s got about 350k miles on an in frame rebuild. I don’t put the miles on the truck, that the previous owner did but it does get used alot periodically. I do spike the fuel with algae killer and Lucas fuel treatment. No leaks, no misses and modest fuel economy. What are your suggestions, for oil change intervals and some other preventative maintenance procedures?
  3. John E.
    John E. Light Load Member
    239
    973
    Apr 4, 2021
    New Brunswick
    You have a great engine in the N-14.My last truck I had was
    an N-14. Put 1.7 million miles on her with 39,500 hrs on it. I changed my oil every 12,000 miles and added a gal of Lucas every oil change.
    I finally spun a bearing because my oil pump gave up. I should have changed it at the million mile marker, mistake I made.
    It was a strong engine, always loaded to max. It would occasionally blow an injector but they were easy to change, did it in a parking lot in Kalamazoo one rainy morning. Changed it in a half an hr. Easy to work on. Yeah, you have a good one.
    Flint1, mile marker 27 and Coffey Thank this.
  4. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    Keep the top end properly adjusted and replace the speed timing sensor periodically.
    John E. and mile marker 27 Thank this.
  5. John E.
    239
    973
    Apr 4, 2021
    New Brunswick
    I never have used Lucas in my fuel, would always put about a cup of automatic transmission fluid in the tanks when I fueled.
    Kept the tips of my injectors just like new and was great for my fuel pump, never replaced or repaired the fuel pump.
    mile marker 27 Thanks this.
  6. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    Did the ATF, color your fuel red?
  7. John E.
    239
    973
    Apr 4, 2021
    New Brunswick
    Yes, makes the fuel darker for sure, depends on how much you put in, sure helps er to run free.
  8. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    I heard tell that there’s a check valve in the fitting that’s on the plate behind the ECM. Said it was in the fitting that goes from the plate to the line that supplies the pump????? Pieces of faulty fuel line can get caught at this spot and cause delayed starting and potential injector faults???? Any of y’all aware of this?
  9. Big Road Skateboard
    7,076
    40,084
    May 2, 2021
    Keep a timing sensor with you, and yes, the fuel check valve in the ecm cooling plate outlet is common to fail or become contaminated. Not all had the check valve though.
    15k on oil change.
    Buy water pump and fan belts, cause they're often hard to find on the road.
    Keep an eye on oil leaks around the accessory drive, and don't let them go too long. If the seal has to be replaced, make sure they do the bushing too.
    Injectors mentioned earlier. If you're going to keep the truck, go ahead and buy one. They are getting hard to find.
    mile marker 27 and John E. Thank this.
  10. John E.
    239
    973
    Apr 4, 2021
    New Brunswick
    Yes there is a check valve, Main fuel line taking fuel to the injectors has a check valve, this can get small pieces of rubber caught in the check valve itself.
    The check valve on my N-14 had the valve going into the block, there inexpensive. Will make your engine run smoother when you remove these object's, if you have any in there. Actually, there are professionals on here who can explain it better than I. Ex: where it is located and it's purpose and so on. Easy fix.
  11. John E.
    239
    973
    Apr 4, 2021
    New Brunswick
