Need advice 2012 Freightliner Casscadia
Discussion in 'Trucks [ Eighteen Wheelers ]' started by united972, Sep 24, 2019.
  1. united972
    united972 Light Load Member
    157
    22
    May 26, 2016
    Hi so im looking at 2012 freightliner with 680k original miles... The truck has a brand new Crate engine with 1 box, radiator, and injectors.
    what is the difference between 2012 and current dd15 engine
    How do you guys say reliability is on a 2012... how many miles can i get out of it?
    do you guys recommending by passing the you know what to make it more reliable or what.
    Please provide any assistance.
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    Current ? you mean 2019 model year?
  4. united972
    157
    22
    May 26, 2016
    curent has in the current generation dd15
  5. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    How many miles ?... from 500k to 1.1m . If you are lucky person you will drive it long. DD15 engine is something unique.
  6. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    Different liners, pistons, turbo, aftertreatment 1 box, sensors, injectors, water pump, fuel pump, egr components,....
    The engine has been updated totally.
  7. OldeSkool
    OldeSkool Road Train Member
    2,029
    6,448
    Jul 17, 2018
    New Hampshire
    If it has a new crate motor probably be a good deal. Definately removing extra "weight " on the engine is a good idea.
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    most likely original engine was replaced at 680k m because of span crankshaft bearing. Long oil change intervals !
    Doealex, bzinger and OldeSkool Thank this.
  9. snowwy
    snowwy Road Train Member
    20,612
    13,331
    Jul 6, 2009
    Wasn't the 12 model a DD13? I know it didn't have the power the 16 I drove had. 450 to 505.
  10. TRS Group
    TRS Group Light Load Member
    93
    117
    Sep 24, 2018
    Look I've got a 2012 with a DD15 in it, it's got 445000 miles on it with a deleted DEF system ...very important on the DEF delete ...they truck is awesome! Its gets me about 6.5 on the highway ...maybe 7, or close to it. It's a very strong reliable engine. I haul all kinds of freight regionally here in Illinois on a flatbed. 48,000 lbs is no problem, it'll pull it with ease. I've had it for over a year now and I'm glad I went with a Cascadia. Only real issue at the beginning was the DEF system acting up and dumbing the truck down but once it got taken care of, it's been nothing but smooth sailing
    OldeSkool Thanks this.
