Need advice!!!!
Discussion in 'Ask An Owner Operator' started by B.I.T, Dec 17, 2020.
  1. B.I.T
    B.I.T Bobtail Member
    5
    Dec 17, 2020
    Please stay safe first and for most. But ive been driving trucks for about 8 yrs now. Its time to start building something to leave my kids. I have everything i need to start off as an owner op. But beings tho im a new owner operator, what engine should i start off with. Im on the east coast. Only looking to do regional. And im buying a used truck in cash. Nomore than 40,000. I understand ima have somewhat high mileage but like i said its my first truck. I aiming for something reliable and that can make back the money i spent before doing any major labor to the truck. All the advice will help. Thanks!!!
    truckdriver31 Thanks this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    do a rig dig report on the truck before you buy it
  4. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    Cash is king right now, and with all the shutdowns there will be bargains everywhere. Just be careful as some that are cash poor right now aren't able to service their trucks as they should be. I would look at a major carrier that has trucks governed to 64 or so. Chances are the trucks are resonably serviced, but as the guy posted, do a background. I assume that company does an oil analysis.
  5. B.I.T
    5
    Dec 17, 2020
    Thank you guys for taking the time to respond. Rig report got it. As far as the trucks from major carriers, do you have any references like websites or something i can look into.
  6. DUNE-T
    DUNE-T Road Train Member
    7,039
    17,145
    May 10, 2015
    Detroit, MI
    With your budget buy a truck with 99 Detroit for $20k and put another $20k in it right after to fix everything you can.
    Or put $40k as a down payment on a new truck.
    Don't buy a 2013 or something like that.
    Opendeckin and Andreybanyuk Thank this.
  7. 201
    201 Road Train Member
    12,747
    26,217
    Apr 16, 2014
    high plains colorado
    Doin' it bass ackwards. Get the hauling account 1st, then a truck. Probably the worst time in history to become an O/O, but I didn't listen. If you simply must, I'd go with a KW.
  8. Eddiec
    Eddiec Road Train Member
    2,318
    3,562
    Feb 2, 2015
    Zach Tate sells trucks
    Bill Stearns at MHC - Memphis, TN.
    Ohio Truck Sales - Sandusky, Oh
    https://www.ohiotrucks.com/
    https://www.preferredtrucktrailer.com/
  9. Chinatown
    Chinatown Road Train Member
    77,638
    183,956
    Aug 28, 2011
    Henderson, NV & Orient
    . Before any tractor goes on the lot, certified mechanics perform an extensive maintenance check to provide the best value of any pre-owed equipment on the road. Detailed inside and out, our tractors come in a variety of colors and include new first-time recap tires, new mattresses and the balance of engine and drivetrain warranties.
  10. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    I started with a 2006 Century. Bought it for 11k and have spent 25k upgrading and rebuilding things over time. 14.0 Detroit in it. Parts are cheap, everything’s pretty easy to work on, it’s not a pretty truck, but it makes money week after week. If you come across a 12.7 Detroit just verify if bull gear has been swapped or not (with paperwork). Only downsides with the truck are cabinets and plastics do shake with a older one, and it’s a plain Jane fleet truck. Upside, with a Detroit it’s a work horse if you drop some money into rebuilding major components to the truck.
    I always suggest 2007 freightliner or older to friends going O/O until you can buy a kw or Pete cash and rebuild all major components cash
  11. Brandt
    Brandt Road Train Member
    4,622
    6,354
    Sep 17, 2012
    It's hard to find good cheap truck today. Basically trucks from 2002-2014 are all first generation of emissions and they had lots of different changes to fix things. Today Freightliner has trouble with the $12,000 One Box emissions box going bad around 600,000 miles and something about seals on engine oil pickup go bad from heat I think. That's easy fix I guess. Cummins ISX had many years of top engine cams going bad from not getting enough oil and all the engine soot. The fuel pumps would go bad and take out the all kinds of stuff. Because some of the first ISX had ceramic fuel pump parts.
    Maybe like others said get older pre emissions engine if you can still find them
