Need advice on securing container on step deck
Discussion in 'Flatbed Trucking Forum' started by PUMPKIN389, Jul 19, 2024.
  1. PUMPKIN389
    PUMPKIN389 Light Load Member
    60
    16
    Dec 7, 2020
    California
    Hello everyone,,.. Good morning from california.
    I got aa new flatbed job to do today so i am seeking some advices to haul this load from point A to point B (1100) miles. Can someones pleasee guide me what precautions i need to haul this loadi am posting aa picture and video. Little info about trailer its step deck spread axle 48 feet. Loaded container on it…. Do i need to double strap it since its only strap on it now…
    Thank you. Safe travels….
  3. Lav-25
    Lav-25 Medium Load Member
    570
    906
    Mar 31, 2018
    If i did it , chain front and back like your picture , and as far as straps , one in front and in back . Big thing is the chains , keep them tight . No flop. Double check height and nothing out side edges of trailer .
    Good luck
  4. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    I would chain it from the top using 1 chain and binder for each corner and crossing them in the front and back. If I was planning on putting more freight on the deck and needed more space, then I would do all lower corners and pull them towards the center of the container on each side. If you feel like you want straps, put a twist in them so it doesn't flap around and damage the paint on the container. If you've chained it correctly, you don't need straps.
    blairandgretchen and Lav-25 Thank this.
  5. Big Road Skateboard
    7,012
    39,649
    May 2, 2021
    Isn't there something about using one chain and binder to secure both sides of a load? Half the WLL? I'm not sure
    Were it me, and I oversecure IMO, I'd have a binder for each corner and straps depending on weight.
    Not saying that's close to right, but what I've done
    I've sern em strapped only too
  6. nikmirbre
    nikmirbre Road Train Member
    5,578
    10,320
    Jul 27, 2011
    High Point NC
    I believe containers have a specific DOT/FMCSA way they are to be secured.
    Loaded containers...all 4 corners must be on the deck. If it were empty you could use only straps.
    Id say you done a good job on that one @PUMPKIN389
    cke, Kyle G. and Big Road Skateboard Thank this.
  7. PUMPKIN389
    60
    16
    Dec 7, 2020
    California
    Thank you sir
  8. PUMPKIN389
    60
    16
    Dec 7, 2020
    California
    Thank you for ur reply will take it into consideration
  9. PUMPKIN389
    60
    16
    Dec 7, 2020
    California
    Thnk you for your reply….
