Need app that shows road construction
Discussion in 'Questions From New Drivers' started by truker88, Jan 16, 2024.
  1. truker88
    truker88 Bobtail Member
    4
    Jan 15, 2024
    Anyone know if there's an app that shows road construction coming up in your route?
    Thank you
    nextgentrucker Thanks this.
  3. nextgentrucker
    nextgentrucker Road Train Member
    1,694
    1,604
    Sep 25, 2023
    Port Saint Lucie, Fl
    That would be great!!!
  4. Tolkien
    Tolkien Bobtail Member
    19
    48
    Apr 5, 2023
    Sothwestern Ohio
    Waze app shows construction.
  5. truker88
    4
    Jan 15, 2024
    I have Waze too but I don't think it shows truck routes does it?
  6. Tolkien
    19
    48
    Apr 5, 2023
    Sothwestern Ohio
    No but if you don't input a destination it still show the construction.
    TX2Day, nextgentrucker and Lav-25 Thank this.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Google maps works good
    And all this "need GPS to show truck route"... use the RM atlas, in the front it tells you everything, when you get off routes like CA for example has many length restrictions, CA has a website showing all the info, use these tools, you will be better off than placing your trust in a "truckers gps." It's just a way for Garmin to sell the same thing with not a whole lot more programming for a much higher price. Especially if you buy it from the truck stop
    nextgentrucker and drh72 Thank this.
  8. MM71
    MM71 Heavy Load Member
    760
    992
    Jun 28, 2008
    AZ
    Good luck .... the state doesn't even know where road construction is at a given time. Ask any OS/OD driver how many times state routing has effed them in a given month to prove this point. Waze crowd sourced info is probably the most accurate.
  9. truker88
    4
    Jan 15, 2024
    Hahaha!:p
  10. truker88
    4
    Jan 15, 2024
    LOL. That's government for you they're neither servants nor civil most of the time
    tscottme Thanks this.
