My 2019 cascadia front light control and 4way fulesher even I can turn on from my sleeper the domme lights I have checked the fues under my glove box but they look ok even tested with fues tester please help in the panel is 4 way flasher which is important for me not getting any power
Need help 2019 cascadia sleeper lights
Discussion in 'Freightliner Forum' started by Rehan, May 30, 2018.
What did freightliner say when you called them?
The interior lights are no longer controlled by the switches themselves.
The switches merely tell the computer to turn on the lights.
The switches up front are all routed through the Multifunction controller which IS the four way flasher module that you push the red triangle to activate the flashers. Only the dealer can change out the module as it needs to be coded by serial number into the computer system.
Assuming I’m reading your composition above correctly, as it is hard to understand what the heck you typed out.
4 Way fulesher = 4 Way flasher ?
Fues = Fuse ?Rehan and driverdriver Thank this. -
What did it say in the owner's manual? Oh yeah.....like that's gonna happen. At least Google it.Rehan and driverdriver Thank this.
I phoned at service department he don't know about fues box location
I've had good luck on the phone with Joplin freightliner and Columbus, Oh
Just to name a few.
Heck there's been times I've called more than a half a dozen shops till I got someone on the phone either not to busy to help and or willing to.
