Need help. Don't have that driving experience
Discussion in 'Questions From New Drivers' started by Dondiego, Dec 5, 2020.
  1. Dondiego
    Dondiego Bobtail Member
    5
    Dec 5, 2020
    I'm new to trucking. Can you guys give me some tips for driving straight, I notice im always drifting. Also need tips for staying steady when going around curves.
  3. Flyingdriver
    Flyingdriver Bobtail Member
    34
    103
    Oct 29, 2020
    Walla Walla WA
    I'm a new driver too. I've been OTR for about 6 months. I'm sure there will much better & more experienced advice than mine.
    I drive a 1999 Pete 378 pulling 53' spud trailer. As I look over hood I try to keep me centered over the middle of the lane I'm traveling in. The center of the lane is usually a different color then where the tires travel. When I do this my trailer tires are about 1' from the fog stripe. It works for me.
  4. tallguy66
    tallguy66 Medium Load Member
    534
    873
    Oct 18, 2018
    If you look in your mirrors enough from the start, you’ll eventually know what to do to keep yourself balanced in your lane.
    Dondiego Thanks this.
  5. Blue Zombie Trucker
    Blue Zombie Trucker Light Load Member
    279
    681
    Nov 1, 2017
    Is the drift due to mechanical issues, such as alignment problems, loose steering linkages, unequal tire air pressures,etc?
    If not, keep your head on a swivel, checking ahead, mirrors, etc, until you really get a feel for where in the lane you need to be. If your steering system is in good shape, it shouldn't have much 'slop.' And remember, in a big truck, you don't have nearly as much clearance on each side as you do in a smaller vehicle.
  6. Dino soar
    Dino soar Road Train Member
    4,815
    27,059
    Dec 8, 2017
    Drive by the yellow line. Get accustomed to where the truck is in relation to that line and follow it.
    If you are in the slow lane judge yourself by the dotted line same as you would by the yellow line.
    If you go around a curve to your left you have to use the line that is at your right front tire.
    The opposite is true if you go around a curve to the right.
  7. gekko1323
    gekko1323 Road Train Member
    1,658
    2,766
    Jul 14, 2018
    Henderson, NV
    With time you'll straighten yourself out (pun intended). But seriously, that used to happen to me too. After a few months I got the hang of it and now it's a piece of cake. You'll be driving with one hand in no time.
  8. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Your mirrors. Remember you are driving a trailer not a truck. So head on a swivel watching where your trailer is in the lines. When in the right lane I try to stay closer to the shoulder.
    Six9GS, Dondiego and rowekmr Thank this.
  9. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Look straight out ahead of you and it will pull you to drive in the center of the lane.
    Don’t be fixated on driving to the white or yellow line.
    Also if you spend to much time Other than a glance at your mirrors you will find yourself driving towards the side of the mirror you are looking in.
  10. tinytim
    tinytim Road Train Member
    5,145
    19,123
    Oct 29, 2007
    Northern Ontario
    Your main should focus should be on where you want to go, not on where you are.
    The further ahead your focus the more consistent you'll be in lane position.
    More importantly, keeping your main focus far ahead gives you time to react to traffic slowdowns, cops on the shoulder etc.
    Dondiego and Daddymow Thank this.
  11. Dondiego
    5
    Dec 5, 2020
    Thanks alot. That really help
