Need help identifying older Pete sleeper
Discussion in 'Peterbilt Forum' started by Dennsco, Dec 22, 2020.
  1. Dennsco
    Dennsco Bobtail Member
    12
    15
    Jun 24, 2020
    Saguache Colorado
    Greetings, hoping someone in here may know what sleeper I have here, does not look like or match any other sleepers I have seen on any petes. It came off a 94 379, narrow or small hole, and 48". Does have peterbilt wiring, but it is squared off on the back instead of the typical radius that matches the front corners. Just curious why this one is different.
  3. 650cat425
    650cat425 Road Train Member
    1,548
    11,043
    Jan 26, 2020
    Pennsyltucky
    @SmallPackage should be able to help out with this.
    Whatever it is, I like it. Sorta reminds me of a bentz, except the front has the usual curve to it.
    SmallPackage and Dennsco Thank this.
  4. Dennsco
    12
    15
    Jun 24, 2020
    Saguache Colorado
    Yea, thanks 650cat, it's different. I tried searching the webs but came up with nothing helpful and cannot find any tag or placard anywhere.
    650cat425 Thanks this.
  5. PSM379
    PSM379 Heavy Load Member
    945
    3,900
    Apr 19, 2019
    That is an ablebody sleeper
    SmallPackage, Roger McG and Dennsco Thank this.
  6. Dennsco
    12
    15
    Jun 24, 2020
    Saguache Colorado
    PSM379, Thanks! Found some pics on the interwebs, it's definatley an Able body!
    Roger McG and 650cat425 Thank this.
  7. PSM379
    945
    3,900
    Apr 19, 2019
    Your welcome, pretty rare. There 70” stand up version was used by Peterbilt also. You can tell it’s a Abelbody by the centered door.
  8. SmallPackage
    5,777
    18,536
    Dec 20, 2019
    Marion Texas
    Sorry l’m late. Yes. Able Manufacturing.
    I have a 36” KW and 48” Able sleeper that was grafted together with a home made fiberglass top to make a double wide 70” walk in sitting up on a rack in my “junk yard”
    Got it from a long time family friend that had it on a ‘68 White-WesternStar back in the 80’s.
    Looks like a flat-sharp cornered kw box with a mix of both style doors and the old “steer horn” Pete top. Unique one of a kind.
    Dennsco Thanks this.
