Need help please!!
Discussion in 'CB Radio Forum' started by shaggychan, May 24, 2020.
  1. shaggychan
    shaggychan Bobtail Member
    11
    8
    May 24, 2020
    Had this issue of me not being able to speak to other drivers on my cb. Mind you it was an old hammy down from my uncle, so it was only a matter of time before it stopped working. But first a buddy of mine lended me his mic to try that and see if it was just my mic that wasn’t working. Even with his mic still no one could hear me. So I went and bought a new cb hooked it up and everything worked perfectly. Then I decided to buy some new antennas and then just created more problems. I bought the Wilson 2000’s for my t680 hooked em up and now I’m getting no sound whatsoever on my cb. Tried to tune antennas but still nothing and swr readings are over 2 and considering it’s a brand new cb I don’t want to mess with it more and mess up my brand new cb because of it
  3. shaggychan
    11
    8
    May 24, 2020
    Kind of at a loss on what to do. I’m currently just going to put the oem antennas back on since they were working and try and see if a cb shop could help me, I just wanted to check and see if maybe anyone knew what’s happening before I put the oem ones back on
  4. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Most likely you bought wilsons with a short shaft...Coil is to low and getting to much reflect...
    Stick with a top loaded fibreglass ant(firestick or skip shooter and keep them as tall as possible but below 13'6")..Pick up some wide braided ground straps and connect both sides of door hinges..this vid will help some..
    shaggychan Thanks this.
  5. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Anytime you install a new antenna, the antenna needs to be tuned (adjusted) to work properly with the radio. Hopefully you find the right CB shop to help you. Also I might add, depending on how old the truck is, it might be wise to install new coax and connectors too.
  6. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Said he tried to tune but no success
  7. shaggychan
    11
    8
    May 24, 2020
    Yeah I tried to tune but still wasn’t getting any transmission at all, plus high swr readings so I didn’t want to mess with it too much and end up messing up the brand new cb radio. So I decided just to put back the oem ones on, and will run with them until I maybe end up getting a firestick
  8. shaggychan
    11
    8
    May 24, 2020
    I had noticed that in a lot of videos that coil just don’t work very well cause they don’t sit higher than the cab/cb in t680’s so I’m running the oem ones again and will eventually get some firesticks!
  9. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    My personal preference is skip shooters but get what you can that has a good rep..As long as its top loaded(wire coils at the top)and tuneable tips,not the ones you tune by cutting the wire..
    Measure from ground up to where antenna is mounted and subtract that from 13'6" ,that will tell you longest ant to buy..Im thinkin 5' or 6' max..
  10. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    you arent trying to tune with the meter that is installed on the cb are you?
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Unless its a high end meter those trk stop ones aint much better than stock.
