Need help with AC issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Brettj3876, May 30, 2020.
  1. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    1993 mack ch
    New receiver/drier & condenser. blew out the lines looking for a blockage. They were clear but im thinking every now and then a piece, o ring maybe will block it up from time to time not all the time. Before we blew the lines out we couldn't get it to take a charge (local AC guy did that) now after getting it to take some it's intermittent working and not the coolest. Condenser fins are fine and cac is 2 yrs old fin are good not blocked.
    What would be next step? Evap core? Before this it would freeze you out on low
    @AModelCat i was reading a post somewhere you seem knowledgeable on ac. Kinda stumped here and so was the AC guy we took it to last fall. The little bit i do know is you'll get false readings on both sides, if something internal is f'd, don't remember the part they were referring to
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    You should’ve changed the expansion valve/orifice tube too, they tend to get clogged and will affect temperatures.
    Rideandrepair Thanks this.
  4. Rideandrepair
    17,503
    56,737
    Aug 8, 2015
    I’d suspect expansion valve malfunctioning. I replaced both of mine. Old ones looked brand new inside. I flushed my evaporators, but couldn’t get them flushed well, no matter how much I flushed them. Not a closed loop. Rail/ fin design.I replaced everything but the evaporators. Wish I would have just replaced them too.
