Need Help with battery question.
Discussion in 'Ask An Owner Operator' started by suubiye, Feb 20, 2015.
  1. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    i would just pop the ground off
  3. Ezrider_48501
    3,845
    5,134
    Apr 2, 2011
    bismarck, nd
    it wont hurt anything to unhook your battery. they may stay up just fine hooked up. but if they do happen to get discharged its hard on the batterys to be fully discharged. so its up to you. will probably be fine to leave them hooked up unless you have a excessive drain or forget to turn something off but if you unhook them you know your be fine. only need to unhook the main neg cable you can leave all the rest hooked up
  4. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    It also depends on the year of the truck, newer trucks have computers running 24-7....the Cascadia has 11 different computers...(battery drain).
