Need help with interior lights
Discussion in 'Kenworth Forum' started by timeranger, Apr 24, 2012.
  1. timeranger
    timeranger Bobtail Member
    Houston
    I have a 2000 Kenworth T2000 and mine does not have this problem. But my friend has a 2006 Kenworth T2000 and his has this feature if you leave the stereo on and the doors open with the cab lights on it starts beeping and then everything cuts off. some sort of safety mechanism to save the battery..............well this feature has stopped working and now he has no interior lights , no map lights, no dome lights. and KW parts counter does not know what this is. maybe someone can point me in the right direction as to were the module might be.
  3. cowcatcher
    cowcatcher Light Load Member
    Its called the low voltage disconnect. You can unhook the lvd box and hook the wiring up to eliminate the lvd box.
  4. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    On my T-600 it is in the drivers side side box. Its towards the front of the box, about 5-6" box with a red cable (almost as big as a battery cable) going in one end and out the other, just unplug the two cables and plug them together to restore the bunk power.
