Need help with spn 792 fmi 7 abs code
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OlegMel, Apr 9, 2023.
  1. OlegMel
    OlegMel Medium Load Member
    610
    1,019
    Apr 8, 2023
    Anybody ever dealt with spn 792 fmi 7 code
    DA Right WSS Wheel End
    Still have this code after repairing broken wire
    what is the cause usually? Thank you,
  3. MWTechGuy
    MWTechGuy Bobtail Member
    17
    6
    Nov 8, 2022
    That fault is WSS signal related. Instead of a clean sine wave the WSS data is "dirty". Super obvious if you use PicoScope or DL8. Most common things are coiled WSS harness, damaged rear wiring harness (Newer FL), replacement harness being WAY too long and dirty/damaged tone ring or wheel-end issues. Also after any repair is made, you have to drive over 5mph for the clean signal to be seen.
  4. OlegMel
    610
    1,019
    Apr 8, 2023
    Thank you, code went away after I drove on the street. Original issue was a short with factory crimp connector in a harness
    MWTechGuy Thanks this.
