need help with trailer light connector
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wr2001, May 1, 2019.
  1. wr2001
    wr2001 Light Load Member
    88
    18
    Apr 27, 2012
    Las Vegas
    am i right in guessing top 2 connectors are W, middle is R turn and bottom 2 are B. its for utility trailer right side turn and brake light. wiring is corroded beyond repair and need a quick road repair. w looks like its for white (ground) b for brown (power) and of course R turn for turn signal.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Clear your mind grasshopper. Do not follow the signs. Sorry I do not remember but you must have terminals for: 1 Right turn. 2 Left turn. 3 Running, tail, marker, clearance lights. 4 Ground. 5 for electric brakes. Brake lights work on the same circuit as the turn signals. Get a test light and work it out. KIMG0742.jpeg
  4. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Why is g r a s s h o p p e r a bad word?
    spsauerland and JReding Thank this.
  5. Flat Earth Trucker
    4,313
    16,533
    Nov 19, 2018
    An over-zealous naughty word filter.
    BoxCarKidd Thanks this.
  6. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    If wr2001 did not understand there was a TV series that had a person nicknamed that. It showed some of his learning process and how he used it later. I thought he was very respectable. Still learning myself.
  7. Canucklehead
    Canucklehead Medium Load Member
    375
    347
    Feb 25, 2010
    Vancouver BC
    I call my wife grasshopper sometimes lol
  8. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    David Carradine Grasshopper.
    spsauerland Thanks this.
  9. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Indicator on the trailer should be its own circuit. On the tractor they share.
  10. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    I was thanking he was pulling a smaller trailer. Looking at the picture back ground it is full sized. Probably a harness plug at the rear of the trailer
    I thought the wiring set up you refer to would be at least 6 wires and we are both referring to tractor trailer connectors? Anyway I am incorrect. Hope he got it worked out.
    spsauerland and HoneyBadger67 Thank this.
  11. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    So there are brown, red and white wires, the indicator wire and (I'm assuming) a black center ground? Does this actually go into the light or is it a pigtail of sorts that connects the light cluster to the main harness?
