Need trailer ABS system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nickornikos, Nov 27, 2016.
  1. Nickornikos
    Nickornikos Bobtail Member
    HELLO.
    MY NAME IS NICK AND I AM TRYING TO FIND AND BUY ABS BRAKE (ANTI-LOCK) SYSTEM FOR THE TRAILER OF MY TRUCK.
    I WONDER IF YOU COULD RECOMMEND A SUPPLIER......
    THANK YOU VERY MUCH.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    A note, all caps is a internet language for screaming at the top of your lungs. Please don't use it if you can help it. Makes you sound desperate.
    Entire Air Ride/ABS systems that go into trailers are expensive. Considering today's slack freight across the entire Industry nation wide you might be able to BUY a modern ABS equipped used trailer for the money it will cost you to ship, install and retrofit a ABS package back there.
    flood and Nickornikos Thank this.
  4. CavScout19d
    CavScout19d Bobtail Member
    13
    4
    Feb 18, 2017
    Any luck .?
  5. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    What part of the abs system needs to be replaced? You need to replace it with the same type and brand. I don't think you will have much luck mixing and matching.
