New drive tire time...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gambi80, Sep 25, 2012.
  1. Gambi80
    Gambi80 Medium Load Member
    Looking for recommendations on drive tires...11r22.5, preferably 'closed shoulder'. Seems tires are worth their weight in gold lately...
  3. Chris50
    Chris50 Medium Load Member
    347
    216
    Jun 21, 2010
    Florida
    I put 8 Michelin XDA Energys on in May and have seen a consistent + .5 mpg avg based on IFTA, I track manually also.. The ride seems about the same as the goodyears that were on there, its hard to notice any small difference i would think. I paid 3450$ thru Weiner, one nice little benny i guess....
  4. HaulnHorses
    HaulnHorses Light Load Member
    88
    33
    Apr 18, 2008
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Michelin XDN2, the last set of them I had I got 432,000 miles out of them. They are expensive to buy up front, but on a cost per mile they are as cheap or cheaper than anything else I have ever tried.
  6. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    M726 EL's are great for tire life, but are probably the absolutely worst tire for fuel mileage out there.
    Try XDA3's or M720's.
  7. gerardo1961
    gerardo1961 Road Train Member
    1,750
    616
    Feb 21, 2010
    Miami
    Before i have yokohama 587 and bridgestone 280 on my steer,was ok ,only after i was going to michelin xzv 3 @,the michelin is for me the best steertire better ,more miles,now 90k and looks like new
  8. rollin coal
    rollin coal Road Train Member
    13,587
    27,943
    Mar 29, 2008
    TN
    Yoko 577 on drives, looks like I'll be lucky to get 300K miles out of them. They look just like the M726's that came on my truck which had irregular lug wear from, I'm assuming torque. I'll never buy anymore of those but they were on the truck like that when I got it. Michilen will be my next set of drives for above mentioned - lowest cost per mile.
  9. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    I'm still liking my Goodyear G572's. They are going to last a long time starting with 30/32 of tread depth. Pricey, but so is everything else with low rolling resistance and deep tread.
  10. tk40176
    tk40176 Light Load Member
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    Depending on what type of trailer you pull, miles / weight you run and the terrains you run - might help you make your choice.
    I pull flat, usually under 3k miles per wk, various weight / dims and gravel/dirt (job sites) - I run General S371 (16 ply) - closed rib / low rolling resistant / anti chunk, etc...
  11. Gambi80
    Was looking at some General D660's.
    These will be on a daycab, dump trailer work mostly...dirt, gravel, rock, asphalt, lots of turning/stopping and starting. Mileage per year varies but is around 40-50k. To get 300k out of any tire isn't possible...150 tops.
