New Freight tractor...?
Discussion in 'Ask An Owner Operator' started by Cat sdp, Jul 30, 2020.
  1. Cat sdp
    Cat sdp . .
    21,289
    76,079
    Apr 8, 2012
    Orion's Belt
    if you were to spec out a new tractor to pull a dry van at 80,000 lbs . What would you do..? Not interested in aero anything. Will be my retirement truck.I’m just planning on all options.....not sure how things will play out....
    What I have so far....
    W900L 255” or 260” wheelbase?
    585/2050 X15 performance
    18 speed manual
    3.25 or 3.55 super 40 rears ?
    11R22.5 tires
    13,xxx front
    46 primax ?
    72” studio high top
    Vit package
    Quite cab and arctic insulation package
    All the usual options...
    No lane departure or vorad type systems
    45” high fifth wheel
    Usage 13’6” high box trailer
    Freight hauling queen tractor. Tare Weight is an issue
    Brettj3876 Thanks this.
  3. dirthaller
    dirthaller Road Train Member
    1,126
    13,404
    Sep 22, 2011
    Coloratah
    Which “Super 40’s”? DT 40-170 or DSH 40? I don’t like either because the DT 40-170 is 500# heavier and the DSH 40 is an odd ball to get parts for. 46 primaxx indicates DT 40-170. I’d get the smaller HP/torque engine to get DSP 40 rears for weight and parts availability.
    AG 400 or AG 400L for suspension. Not exactly sure of the ride height difference or weight but the AG 400L would be cheaper to maintain and has more suspension travel. The AG 400 “walks” better and you can run with suspension deflated for a few miles with a blown airbag. AG 400L is dead in the water with a blown airbag.
    3.36 and 3.42 is available between 3.55 and 3.25. You’ll have to research what speed/rpm is your “sweet spot”.
    ETA: AG 380 is an excellent light weight, cheap to maintain suspension. I’ve found no fault in the AG 380 unless you’re pulling a RGN and you need occasional > #40,000 of strength on your drive axles.
    Crude Truckin', Tug Toy and alds Thank this.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Tare weight an issue. Well that new truck will be heavy no matter what with polar bear saving equipment hanging off it. Something like a Hyundai van be lighter than a dane. Im 32.4-32.6 with a 53 hyd plate van
    Rubber duck kw Thanks this.
  5. dirthaller
    1,126
    13,404
    Sep 22, 2011
    Coloratah
    20 years ago, when I knew how to spec a w9, the way to spec a lighter studio was:
    22” tanks (to allow for 5/16” thick framerails instead of 3/8“) 255” wheelbase, AG380, DSP 40 rears. The 13,200 front shouldn’t make a noticeable difference in weight.
    Brettj3876 and Cat sdp Thank this.
  6. AModelCat
    164,493
    The MX is like 400 lbs lighter :p
  7. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Or the X12 lol still like 1700 or 1750tq plenty for 80k
    alds Thanks this.
  8. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Moved plenty of frac pumps at 100k with the 425/1650 and I was impressed better than volvo d13 and dd15
  9. dclerici1
    dclerici1 Medium Load Member
    527
    1,589
    Aug 1, 2012
    Shell Knob, Missouri
    If weights an issue, drop the primax. You don’t need that for a dry van.
    Long FLD and alds Thank this.
  10. 201
    201 Road Train Member
    12,756
    26,246
    Apr 16, 2014
    high plains colorado
    Thank you, a breath of fresh air. I was hoping you wouldn't say the "F" or "V" words. Sounds great, personally, I'm sick of shifting, but don't want an automatic, I'd go with a simple 10 speed and the 3:55's. No need to "split" any gears these days, and costly to repair. You'll have the power for the hills, as long as you aren't a clutch abuser, and since you aren't going trail blazing, a 10 speed should be just fine. Empty weight might be an issue, but skimping on tractor options, doesn't save much. Good luck:thumbup:
    Speed_Drums Thanks this.
  11. dirthaller
    1,126
    13,404
    Sep 22, 2011
    Coloratah
    Why on earth would a self respecting owner operator NOT get a 13 or 18? They add very little weight and they are EVERY bit as dependable (unless you’re a real ####ty driver or you’re stuck in the 1980’s)!
    alds Thanks this.
