New Rules Starting Monday
Discussion in 'YRC' started by BubbaDog, Jun 29, 2013.
  1. BubbaDog
    BubbaDog Bobtail Member
    44
    21
    Aug 2, 2009
    Philadelphia,pa
    Just a reminder for everyone
    [TABLE]
    [TR]
    [TD="bgcolor: #F0A900"]PROPERTY-CARRYINg CMV DRIVERS (Valid as of July 1, 2013)
    [/TD]
    [/TR]
    [TR]
    [TD]11-Hour Driving Limit
    May drive a maximum of 11 hours after 10 consecutive hours off duty.
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E6E6E6"]14-Hour Limit
    May not drive beyond the 14th consecutive hour after coming on duty, following 10 consecutive hours off duty. Off-duty time does not extend the 14-hour period.
    [/TD]
    [/TR]
    [TR]
    [TD]Rest Breaks
    May drive only if 8 hours or less have passed since end of driver’s last off-duty or sleeper berth period of at least 30 minutes. [49 CFR 397.5 mandatory "in attendance" time may be included in break if no other duties performed]
    [/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E6E6E6"]60/70-Hour On-Duty Limit
    May not drive after 60/70 hours on duty in 7/8 consecutive days. A driver may restart a 7/8 consecutive day period after taking 34 or more consecutive hours off duty. Must include two periods from 1 a.m. to 5 a.m. home terminal time, and may only be used once per week, or 168 hours, measured from the beginning of the previous restart.
    [/TD]
    [/TR]
    [TR]
    [TD]Sleeper Berth Provision
    Drivers using the sleeper berth provision must take at least 8 consecutive hours in the sleeper berth, plus a separate 2 consecutive hours either in the sleeper berth, off duty, or any combination of the two.
    [/TD]
    [/TR]
    [/TABLE]
  3. Wanderingaimlessly
    Wanderingaimlessly Medium Load Member
    445
    287
    Jun 18, 2013
    Los Angeles, Ca
    The only new tweak to regs out of that list is the the required 30 minute sleeper or off- duty within the first 8 hours of driving. Along with the once a week 34 hr restart. Am I missing something? Not that hard to work around the break. Spent numerous times logged off duty for 30 minutes while waiting in a fuel line.
  4. CertifiedSweetie
    CertifiedSweetie Road Train Member
    1,489
    1,634
    Nov 18, 2008
    Pittsburgh,Pa
    I'm only confused on the 60/70 rule.
    Sent from my DROID RAZR using Tapatalk 2
  5. Dinomite
    Dinomite Road Train Member
    4,092
    4,308
    Sep 6, 2012
    Looking 4 Rocks
    You missing the fact that the 2 periods of your restart must be between 1 and 5 am. This is going to screw me out of a restart come Monday. I should be at receiver tomorrow at 2pm. I don't deliver till Monday at 8am. If regular rules. I would have a restart by Monday Midnight/Tuesday 0001. Now I would have to wait till 5 am. My next load picks up Monday night at 22:00 and I can pick it up later if I wanted but picking it up at 7 am instead of 2 am is not worth it. Guess I'll have to run on recap hours.
  6. fisher guy
    fisher guy Road Train Member
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    doesnt the 30 min break require at least 3 hours working before u are allowed to take it?
  7. cuzzin it
    cuzzin it Road Train Member
    3,641
    12,427
    Jan 19, 2008
    Berea, KY
    No but you only get 8 hrs of your 14 when you take it so if you run 2 hours and stop for 30 you need another if you want to drive more than 10 that day
    fisher guy Thanks this.
  8. ethos
    ethos Road Train Member
    4,252
    13,458
    Mar 3, 2013
    Fort Worth
    As I understand it the thirty minute break is required whenever you drive 8 hours at most. Meaning you can take your 30 minute break at 2 hours in and reset your 8 hour clock. Basically every time you stop for 30 it resets. At least this is the way I understand it.
  9. peterd
    peterd Medium Load Member
    349
    365
    Jan 7, 2012
    St.Catharines ON
    No.You have to take 30 minute break before driving past 8 hrs.
    kw600 and fisher guy Thank this.
  10. cuzzin it
    3,641
    12,427
    Jan 19, 2008
    Berea, KY
    it goes by on duty (14 hr) clock
  11. Wanderingaimlessly
    445
    287
    Jun 18, 2013
    Los Angeles, Ca
    yeah forgot about the mandatory 2 periods between 1 am and 5 am on the 34 restart. Looks like in order to achieve that you are going to have to start a restart no earlier than 1900. This will require more planning than before when you could just say I'm on a 34.
