new to cb's... need some help
Discussion in 'CB Radio Forum' started by Shadowhawk01, Jul 9, 2013.
  1. Shadowhawk01
    Shadowhawk01 Bobtail Member
    39
    8
    Aug 28, 2012
    I Just Started Driving Truck Last Ma And After Training I Am Now In My Own Truck Which Is A 06 International 9400I. I.have A Cobra 29Ltd ClasSic In It And I Have Noticed My Range Absolutely Sucks. I Am Lucky IF I Am Able To Recieve At A Distance Of A Quarter Mile Amd I Habe NO Idea Ho Well I Transmit. Can Sombod TellE What I.need To Do To Get Better Quality Re Ieve And.transmit Signals. Sorry FOr All THe Typos... My Phone Is Not Liking These Forums For Aome Reason.
  3. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Well first you have to make sure your radio is working properly. They break, so check that out first. Then you need a good antenna and good coax. The stuff that comes in your truck is not considered "good stuff". Although there are a few good factory coax and antenna combinations that will work at least decently, yours is old enough that I would just go ahead and get all new coax as well as a quality antenna. Install it all and check your SWR. If it is below 2:1, you are good to go. If is 3:1 or higher, you probably have a rf ground problem. Here is the solution for that: (see post #7) The only thing I would add is be sure to "shiny up" your contact points and spray paint or undercoat on them after all connections are made to prevent rust of the bare metal you just exposed.
    http://www.thetruckersreport.com/tr...-radio-forum/218058-ch-mack-and-high-swr.html
  4. Shadowhawk01
    39
    8
    Aug 28, 2012
    Like I Said Im PRetty New To The Cb World. So Im Assuming You Are Telling Me To Change Out The Antenna And Wire. How Do I Check The Swr? How Do I Know What ANtannas Aregood. Is All Coax The Same?
  5. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Read your owner manual for cobra29 I believe it has built in swr meter. If not, or need a better one check any truckstop or Ratshack approx $20-$40.
    Antenna standing wave ratio (SWR) is everything, your goal is less than 1:2.0, perfect is 1:1.0. This is the amount of energy you are wasting and sending back at the radio... if over 1:3 you will burn up radio over time.
    since you are new, suggest a single antenna and new coax(RG-58, RG-8x, mini-8 ) if you are out of guide line. Route new coax wisely so its not smashed in door, and give it good ground connection... then trim it to best SWR.
  6. Ridgeline
    22,717
    123,136
    Is it your truck, meaning you own it or is it a company truck?
  7. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    You check the SWR with an SWR meter. You want 1.5:1 to 2.0:1. The higher your SWR = less range.
    1.5:1 = 96% of your signal is getting out. 2.0:1 = 89% of your signal is getting out. The opposition to this is going back down into the radio as heat. With a high SWR, the finals will overheat and burnout, rendering the radio inoperable to transmit.
    Good antenna would be a Wilson 2000
    Good coax would be RG8X
    The antenna is what dictates your range both transmit and receive. When it comes to antenna, height is might. You want the antenna as high as you can get it and you want the tallest to a 9 ft antenna as you can get it. No you probably can't do this with a truck, but a 5 ft Wilson 2k beats the pants off of a 3 foot Firestick any day, all else being equal.
    Most trucks run piss poor antennas (3 and 4 ft) because 1. height restrictions and 2. because most truckers don't understand how a radio transceiver works. The sucky thing about CB is in all reality you need a 9 ft antenna to get out correctly, but for a semi that's too tall, so they made "compromise antennas" to get around that....and that is what they are....you compromise range for size.
    With coax, if you get the cheap coax, it will be "lossy" and not allow the full signal to get out the antenna. The higher in frequency you go, the better coax you need. RG8X is good for 27 MHz.
    Hopefully this helps you understand
    drloveofdfw Thanks this.
  8. Shadowhawk01
    39
    8
    Aug 28, 2012
    Thanks For The Help. Its A Company Truck So Im Not Sure If I Really Want.To Put Too Much Money Into It. As Far As An Owners Manual That Im S.O.L. There Is A Switch On The Far Left Of The Cb That Has 3 Settings. S/Rf, Swr And Cal. Is That The Built In Swr CalibrateR? As Far As My Antanna Goes It Looks Like A Plain Jane White 4 Ft Antenna. DoNt See Any Markings Or Manufactures Stickers. If The Switch On The Left Is The Calibration How Do I Go About Calibrating? Ugh I Hate Being A Noob Sometimes.
  9. prisonerofthehighway
    prisonerofthehighway Light Load Member
    157
    101
    Dec 28, 2012
    Cedar Rapids, Ia
    Let's take care of your problem one step at a time ok.. First receiving. Nothing you do to your radio is gonna effect the recieve ability other then the rf gain. Have your SWR's checked and your antennas. Make sure that your bracket is properly grounded and your coax isn't all boogered up ie kinked, looped, cut, or pinched. That should take care of your recieve prob. Remember, you get what you pay for, if you buy $15 antennas then you'll get $15 dollars worth of perfomance. If you have a 29ltd, which is a good radio , you don't need anything bigger then wilson 1000 trucker antennas. The db gain on them is excellent and not to mention if you decide to upgrade your radio then you'll have broadbanded enough ants to handle it. Remember, you set the SWR's of an ant to the truck, not the radio. Secondly, transmitting problems,,,, see above and if that is all good, then you can have your radio " peaked and tuned" and that will help with transmitting. Are you running factory coax? If so, spend a couple bucks and get some new stuff ran. They don't measure it very well at the factory, it's mass produced. Find yourself a good cb shop and tell them to check swrs and ants, don't get fooled, actually have them show you the meter and what it is saying. Send me a pm and i'll send ya a list of cb shops that i've dealt with and had good luck with them. Also,,, you don't need a ant that will handle 10,000 watts for your radio. They are gonna try and tell you you need it for one reason or another, wilson 1000's and you'll be good to go and maybe some new coax. Hope this helps.
  10. Tall One
    Tall One Bobtail Member
    19
    14
    Jul 7, 2013
    If he's a noob, he might have a tuff time setting his SWR on the Wilson. I would get new coax, and a single Francis 4 footer. Also, make sure your rf gain and mike gain are turned up. A good peak and tune and a road king mic would help u as well.
