New to Step Deck
Discussion in 'Flatbed Trucking Forum' started by T J, Mar 18, 2012.
  1. T J
    T J Bobtail Member
    Mar 18, 2012
    girard, oh
    Hello, I have been driving van, reefer and tanker for years. I am ready to buy a step deck, 48' x 102", 11 ft upper/37 ft down.
    What other goodies do you flat deck/step deck experts recommend I get?
    Chains? Binders? Straps? Ratchets? Load levelers / Ramps? Tarps?
    I am getting fat and lazy with the van and need more exercise so the step deck will help.
    Thanks, T J
    SHC Thanks this.
  3. Allow Me.
    10,762
    12,560
    May 28, 2009
    Rancho Mirage, Ca.
    Everything mentioned is a must.....except load levelers/ramps, unless you'll be hauling vehicles/48' loads.
  4. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    why not get a 50' or a 51' step? that way you can pull loads for a 53' but without the added wasted space and weight, and the stupid sliding axles. 50' and 51' trailers are legal with a regular fixed spread in all 50 states and canada. Also you'll have a 10' or 11' top deck and a 40" bottom deck, allowing you to haul TWO 20' containers or One 40' container....You can spec trainers with contrainer locks so you dont need to put all the chains/straps on it (although i would still throw a few straps over it anyway).
    Get it with a Lifting front axle (to save 1mpg while deadheading) and a rear axle dump valve (to make the trailer pivot on the front axle to get into tight spots)
    American Trucker
    Elroythekid and bergy Thank this.
  5. DMH
    DMH Medium Load Member
    344
    110
    Jan 9, 2012
    the price difference probally.
    Mommas_money_maker Thanks this.
  6. thedrifter
    thedrifter Medium Load Member
    522
    263
    May 23, 2010
    portland or.
    No AT spreads ARE not legeal in all parts of Canada.
    Mommas_money_maker and SHC Thank this.
  7. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    Chains? yep, I carry 12 of them
    Binders? yep, I carry 12 of them
    Straps? yep, I have 24 sliding winches, I carry a strap for each and 2 extra's.
    Ratchets? umm what kind? I have ratchet straps, ratchet binders so exactly what are you asking?
    Load levelers/Ramps? nope I dont carry them but nice to have on occasion
    Tarps? yep, this oneis your hardest decision as you need to figure out what mostly you will be hauling. Should have been thinking of this BEFORE you spend money on the trailer. Make sure you are buying a trailer that will suit your area and needs.
    SHC and Clasix1055 Thank this.
  8. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Triple M hit it dead on, buy a trailer and equipment for what YOU plan to haul. I would suggest just for the basics:
    12 chains and binders
    12 4" straps
    12 2" ratchet straps
    40 edge protectors
    Lots of extra rubber strips (old mud flaps work good)
    Hammer and nails
    4x4x8 lumber
    With a SD I would also suggest t,j,r hooks and some axle straps.
    As for a trailer, a 48x102 will do just fine. And if u can find one with a low deck height then you'd be really well off. Many loads for a SD can be oversize in height, but if u have the lower deck u will not be OS but can still get the OS rates ;)
  9. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    "why not get a 50' or a 51' step? that way you can pull loads for a 53' but without the added wasted space and weight, and the stupid sliding axles. 50' and 51' trailers are legal with a regular fixed spread in all 50 states and canada."
    Not altogether correct. Any trailer over 48' must maintain a 41' kingpin to rearmost axle measurement in California. If your spread is fixed, you still have to keep the rear axle at 41', huge overhang. Might get away with a 50' for awhile. I agree with the 40' bottom for reasons already mentioned.
    My step is a 8/40 with can locks.
  10. Mommas_money_maker
    1,122
    765
    Oct 2, 2011
    North Carolina
    Thanks SHC and Triple M has a nice ring to it, I like it.
    SHC has a good starter list there and there are tons of things you can and will carry. I know I have replied to threads before the flatbed forum was started that had very detailed lists on flatbed equipment carried. I guess we could start a thread here if needed.
  11. swenjj
    swenjj Light Load Member
    156
    34
    Apr 11, 2010
    St.Croix Falls , WI.
    i carry 8 coil racks and enough 4x4x8 lumber for at least 3 coils, so four, but have had to scrounge for more before. seems like every return load i get is coils.
